Thread: Trans question
Results 1 to 2 of 2
  1. #1 Trans question
    SE Level Member davidl25's Avatar
    Apr 2009
    evansville in.
    Ok ive got a 98 gp. Im replacing the trans and needing to know what is the newest year i can go with? So can i put a tranny out of an 04 gp in my 98 gp with out any mods. Thanks for any help.
    99 GP (SE) GT Clone, KYB AGX struts + SSC springs, GMPP sway bars, GMPP trailing arms, OTTO strut tower brace,Big 3 mod, Stage 2 voltage booster, alt rewire, 180 t stat, HID conversion, D/S rotos and ceramic pads,cold air intake, and an insane car audio setup 150+ db.
  2. #2 Re: Trans question
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    You can use up to an 02 trans as a direct drop in. 03+ models have different internal electrics and use a different style pressure control solenoid and must be used with an 03 PCM which some guys have done without problems. The important thing to do is get the ID tag info off of your original trans and one that you are looking at and either post up on here or send me an email with this info so we can help let you know if it will be compatible as there are different gear ratios in the all models and if you dont replace your original trans with a matching gear ratio trans it will cause problems.
  1. F4EAT trans Question (trannyman)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2010, 04:42 PM
  2. Trans question
    By CompCam21 in forum Introductions/Noob Questions
    Last Post: 06-14-2009, 11:38 PM
  3. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  4. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  5. I guess a newb question about trans fluid
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2008, 02:00 AM
