![Quote](https://www.grandprixforums.com/images/redfox/misc/quote_icon.png)
Trannyman95
If you are pulling the trans solo then it has to be removed from the bottom. This will require you to have some sort of engine support to hold the engine and trans up as you must remove the cradle from the bottom of the car. If it was my car and was going to do engine gaskets and a timing chain I would yank it form the top hands down. I can have the whole thing out in 2 hours start to finish by myself including draining all fluids. I have done this MANY times though so I would give yourself a full day to take the time and carefully look over everything and keep track of where everything goes. Yes you do need to unbolt the brake master cylinder but that is no big deal, its only two 15mm head nuts and then it moves right over and you will need a bungy cord or something to hold it out of the way. It can be tricking getting things out and putting them back in but I have done it so many times I dont even think about it. The bracket on the side of the trans likes to hang up on stuff so after I start pulling the engine/trans up with a engine lift I will unbolt the side bracket for more clearance. If the car still has stock exhaust manifolds on you dont even need to remove them, just unbolt the downpipe. You need to unbolt the PS pump and AC compressor from the front of the engine and thats about it. I prefer doing it this way for taking the whole thing out as it is quick to do and leaves the car movable, you dont need to remove the cradle from the car though you do need to pop out the axles still.
