Thread: Dynotech input shaft, 1" chain
Results 1 to 6 of 6
  1. #1 Dynotech input shaft, 1" chain
    I live here. UR LOSN's Avatar
    Rockford, IL
    does anyone have any experience with these items?
    I like the 300m input shaft from dynotech...I have yet to hear of one breaking.....
    I also havent heard of the 1" chain breaking...
    let me know your thoughst and ideas....
  2. #2 Re: Dynotech input shaft, 1" chain
    Oklahoma
    Are you yanking our chain?
    Sorry, I just had to, couldnt resist.
  3. #3 Re: Dynotech input shaft, 1" chain
    Rockford, IL
    HA!
    bueller........bueller
  4. #4 Re: Dynotech input shaft, 1" chain
    Banned
    New Port Richey Florida
    I have not heard a single word good or bad about them so i don't know
  5. #5 Re: Dynotech input shaft, 1" chain
    SE Level Member GTP2K1's Avatar
    Tampa, FL
    Input shaft... if its anything like ZZP or Intenses... should be overkill (but in a good way).
    As far as the 1" chain; Do you know who these 1"chains are actually made by?
    I'd assume they are the GMR 1" chains. To which Ive only heard of one negative case but still probably the best you can get ($$$ to the tune of ~$850) But I'm sure you know you gotta pay to play if your asking about these parts. An recommended by Stattama for "All (turbo)kits over 14psi or 400WHP."
    But perhaps Dynotech has someone else making them? I highly doubt it but if so... your guess is as good as mine. I'd make sure it is the GMracing chain if I were you.
    Cheap, Fast, Reliable... you can only pick two
    http://www.cnfcgp.com/
  6. #6 Re: Dynotech input shaft, 1" chain
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I just installed a Dynotech input shaft and GM Racing 1" chain setup in a trans a few weeks back. The gears come in a box with GM Racing right on it and a part number but its not going to do any good at the dealer and I dont know anyone aside Dynotech or W-body Store that sells them. I have heard of some issues with the reluctor wheel from Mike at W-body store but the set I recieved was modified and ready to install and fitment was just fine. They are brand new forged gears and a 1" wide chain which is similar to the 7/8" chain just a few links wider, but it is the same rocker type HY-VO style chain construction.
  1. CV Shaft
    By webracin in forum Shops and Community Heroes
    Last Post: 04-15-2008, 01:38 AM
  2. intense input shaft
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2008, 02:54 PM
  3. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
