Thread: alright..just bought my car...
Results 1 to 12 of 12
  1. #1 alright..just bought my car...
    Ohio/North Carolina
    and I'm reading through the posts and there seems to be a trend of problems with our tranny's. I've got a 2002 GTP. Now my tranny seems to be doing juuuuust fine...and I'd like to keep it that way..
    I remember when I bought my first car (97 thunderbird) it was advised to install the shift kit because it replaced some gaskets and seals and just made it shift cleaner. I also bought a chip because it was designed to shift at more logical RPM's depending on how you were driving.
    What are some options for our cars to make our transmissions a little bit sturdier and shift a little bit better?
    Thanks!
  2. #2 Re: alright..just bought my car...
    Jan 2009
    hammond, IN
    ive herad a pcm is better for the trans
    (sold)GTP-Intense pcm,zzp 3.4 pulley, colder plugs, zzp dp, magnaflow converter, k&n intake, autometer gauges, zzp motor mounts, u bend delete, res delete, 180 stat
    1997 lt1 formula- to many mods to list.
  3. #3 Re: alright..just bought my car...
    Ohio/North Carolina
    is that confirmed?
  4. #4 Re: alright..just bought my car...
    Dec 2008
    Canada
    Chips... no get a shift kit and a tune and you should be set if that's all you want to do with it.
  5. #5 Re: alright..just bought my car...
    May 2008
    McHenry IL
    sounds like good advise 2 me =]
  6. #6 Re: alright..just bought my car...
    CT
    get the Intense shift kit, worst mistake I made was getting the ZZP shift kit, its cheap and ****. Works but doesn't do it like it should. Then get a nice PCM to help with it.
  7. #7 Re: alright..just bought my car...
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    Props on the Tbird good choice!! The 4R70W was solid in 97; did you add a Trans cooler too? (trying to sell my 95' Stage 2 TransGo VB Still!) I will agree the same should go for ANY tranny to help keep it alive and kicking. A shift Kit (unfortunately there is no J-Modding these), Tune and i would even add a trans cooler W/Fan and maybe switch to Royal Purple Synth Fluid to keep it cool and lubed up
  8. #8 Re: alright..just bought my car...
    Ohio/North Carolina
    lol good ol j-mod..
    that was the difference between tccoa and here...on there there was a concrete, solid way to improve whatever you wanted to improve. Wanna improve the tranny? Get a MK8 Driveshaft, shift kit/jmod, and a jerry tune and you were good to go. And you would probably shave a tenth or so.
    Here there's a thousand options and noone has a concrete answer on what to do lol
  9. #9 Re: alright..just bought my car...
    Nov 2008
    Hauppauge, NY
    LOL, yeah i hear ya, a lot more opinions on what is Best here, Tho the General Consensus is Stay away from ZZP PCM's LOL, the Intense Kit from what i have read around here seems to the the Go To Kit, Trannyman is the Trans Expert here, im sure he will Chime in with his view, I would say Def go with a Shift Kit, Trans Cooler w/fan and some Royal Purple, the Bird and GP are two totally different beasts, i wish Mods were easy for these cars as they were on the bird, I mean come on, whats easier than dropping the pan and teh VB drilling a few Holes, remove a spring or two and get nothing but neck snapping tire eating shifts every time
  10. #10 Re: alright..just bought my car...
    Ohio/North Carolina
    yeah...i was chirping 2nd gear with no other mods than the tranny stuff...it was pretty snazzy...
    then i did some p&p'd PI heads and a few other things and i was chirping into 3rd gear...
    i miss my bird
  11. #11 Re: alright..just bought my car...
    Ohio/North Carolina
    where did you get your shift kit and cooler from again?
  12. #12 Re: alright..just bought my car...
    Nov 2008
    Hauppauge, NY
    Quote Originally Posted by virility26 View Post
    for this car? i dont have one, just leaving it as is, its got 106k on it, not gonna mess with it already had one trans issue dont need more lol,
  1. alright it's question time...
    By virility26 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2009, 04:46 PM
  2. alright some expertise please
    By 40mphGT in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-02-2009, 05:08 PM
  3. alright i got an issue :(
    By Myprixxx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-25-2009, 01:28 PM
  4. alright guys, give me all of your opinions on my idea.
    By pontiacgp759 in forum Tires & Wheels
    Last Post: 03-01-2009, 05:50 PM
  5. Alright, parts are here.. now what?
    By Saturate15 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2008, 10:00 PM
