Thread: Added wiring for Performance Shift now what?
Results 1 to 6 of 6
  1. #1 Added wiring for Performance Shift now what?
    Wichita, Kansas
    First I am new to this site so if I posted this in the wrong place please accept my apologies! Anyway, I want to enable the performance shift option on my 02 Grand Prix. I know this was not avaliable that year so I purchased the shift knob and harness from PFYC and installed both. I installed the wire in pin 21 on the computer and tested that the switch supplies a ground (it does). However, I do not think it is working. I noticed there is a 'performance shift' indicator on the instrument cluster, which I believe should light up (it does not). In addition, after reading member GeddyLee's how to on performance shift, the following was at the end of the article:
    "The last important thing to note that Swash discovered is that you need to make sure your PCM is setup to know it has the performance shift available.
    Here are tips for checking that.
    1) Calibration Data-->Transmission-->Shift Switch-->Shift_Switch_Type = set this to 1 (default is 0)
    2) Calibration Data-->Transmission-->Shift Switch-->Discrete_Switch_Debounce_Time = 25 (currently yours is 200 (I believe this is the factory default))"
    My questions:
    1. Do I need to put a lamp in the instrument cluster? (I am quite sure GM would not put a lamp in an indicator that is not used.)
    2. I assume the item about making sure the PCM knows it has performance shift involves changing settings in the computers software, if so how is this accomplished? If not what exactly needs to be done to enable the performance shift?
    Any and all help will be greatly appreciated!! Thanks in advance.
    Doc
  2. #2 Re: Added wiring for Performance Shift now what?
    May 2008
    McHenry IL
    throw a bulb in the back of the cluster man see if that works for ya it illuminated blue =]
  3. #3 Re: Added wiring for Performance Shift now what?
    Wichita, Kansas
    Thanks for the info will get to work on that. You don't by any chance know anything about the computer calibration changes I memtioned? Or can point me in the direction of someone who does?
  4. #4 Re: Added wiring for Performance Shift now what?
    GT Level Member skidoojames151's Avatar
    seattle
    hp tuner or performance pcm from intense, zzp, 3800 performance...
  5. #5 Re: Added wiring for Performance Shift now what?
    Topeka, KS
    I did the install straight from that writeup for another member and after i completed it the dash light lit right up. But..... He already had a tune for the performance shift to be enabled. Thus you need a tuned PCM or someone to tune your PCM.
    Hope that helps.
    -Ryan
  6. #6 Re: Added wiring for Performance Shift now what?
    Wichita, Kansas
    Yes this does help, can this 'tuning' be done with a scan tool? or do they use a PC? I guess what I am asking is who does this sort of thing? I really can't afford an aftermarket PCM right now although I am well aware they are out there. Thanks again for all your help!
    Ken
  1. Performance Shift Wiring
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 05-08-2009, 05:35 PM
  2. performance shift and TCS
    Last Post: 03-05-2009, 11:30 AM
  3. performance shift WTH?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-08-2008, 09:44 PM
  4. performance shift
    By Scott B in forum General Tech Discussion
    Last Post: 06-29-2008, 08:40 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
