Thread: tranny swap,radiator question
Results 1 to 3 of 3
  1. #1 tranny swap,radiator question
    Apr 2009
    Mississippi
    following up on my previous post on the 98 GTP 4T65E HD tranny problem.i have a question being the trannys from my 98 GTP and the 01 GTP are the same,being the only difference is the coolant line fittings.Will i have to replace the radiator in this tranny swap?or,can you buy some fittings to do the swap with?or,will the coolant line fittings off the 01 GTP interchange with the 98 GTP?just wondering thanks.
  2. #2 Re: tranny swap,radiator question
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Simplest way would be to get the lines from the 01 GTP along with the trans. The fittings on the radiator side are the same, so nothing needed there.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: tranny swap,radiator question
    TDCRacing
    Guest
    GTP to GTP should be fine.
    If both of the transmission cooler lines have screw in fittings on one end then either of the lines will work.
    If one of the transmission's lines has the same connectors on both ends of the line then you will need to keep the lines from the new transmission that you are getting for the swap.
  1. tranny swap
    By kbradley in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2009, 04:59 PM
  2. tranny swap
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2009, 08:41 AM
  3. pcm help with tranny swap
    By ddyke2000 in forum PCM Tuning
    Last Post: 05-03-2009, 01:41 PM
  4. Tranny swap
    Last Post: 04-23-2009, 07:45 AM
  5. Getting ready to swap the tranny chain...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2008, 10:49 AM
