Thread: (Solved) Trannyman Help! im in the middle of trans filter change.
Results 1 to 12 of 12
  1. #1 (Solved) Trannyman Help! im in the middle of trans filter change.
    Ohio
    Help im in the midst of changing my trans filter an this thing fell out an im not sure which way it goes.
    it goes here
    and the part looks like this.
    00 GTP demodded and forsale
  2. #2 Re: Trannyman Help! im in the middle of trans filter change.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The point of the "V" should be holding that plate in place.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Trannyman Help! im in the middle of trans filter change.
    Ohio
    ok one end is longer than the other though. which way does it go?
  4. #4 Re: Trannyman Help! im in the middle of trans filter change.
    Barksdale AFB, LA
    See if this helps:
    2009 Subaru Impreza WRX STI
  5. #5 Re: Trannyman Help! im in the middle of trans filter change.
    Ohio
    awesome thanks sabrewings.
  6. #6 Re: Trannyman Help! im in the middle of trans filter change.
    Barksdale AFB, LA
    No problem. I have my camera with me anytime I work on my car.
  7. #7 Re: Trannyman Help! im in the middle of trans filter change.
    Ohio
    **** i just looked at the new filter an it says 4t80e and 4t85e instead of 4t60e and 4t65e is that a problem? it looks exactly the same accept the big slot on the bottom is in a slightly different spot but its the one autozones computer said.
  8. #8 Re: Trannyman Help! im in the middle of trans filter change.
    Barksdale AFB, LA
    Never tried to fit a 4T80/85 filter before. Gonna have to wait for trannyman or someone else on that one.
  9. #9 Re: Trannyman Help! im in the middle of trans filter change.
    Ohio
    Thanks sabre. yea it woulda been interesting but i went back out there after i wrote that to double chack an figured out i misread it while i was laying on my back under the car with the light in a funny spot. turns out it is the right one so i put it in an put the pan back up. so alls well. thanks for the help
  10. #10 Re: (Solved) Trannyman Help! im in the middle of trans filter change.
    Barksdale AFB, LA
    Good stuff. Glad I could help.
  11. #11 Re: (Solved) Trannyman Help! im in the middle of trans filter change.
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Sorry I am late to the party, glad you got it figured out ok!
  12. #12 Re: (Solved) Trannyman Help! im in the middle of trans filter change.
    Ohio
    ^ its alright others joined the party that knew what was goin on so alls good
  1. 14* of KR..........Trannyman?
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2009, 11:18 AM
  2. Thanks Trannyman... trans feels good.
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2009, 01:26 AM
  3. Trannyman
    By black.gtp in forum Off Topic Discussion
    Last Post: 07-26-2008, 11:04 PM
  4. So who here thinks Trannyman should change his profile?
    By Zef_66 in forum Off Topic Discussion
    Last Post: 02-26-2008, 09:39 PM
