Thread: Driver's side axle / halfshaft issue...
Results 1 to 11 of 11
Threaded View
  1. #1 Driver's side axle / halfshaft issue...
    SE Level Member GrandPrixGT300's Avatar
    Sandusky, OH
    I cannot get the shaft to snap in over the compression ring. The passengers side went on in maybe a minute. I lubed the crap out of the driver side and tried having the ring pointed in different directions to no avail. Anyone have a trick to shock the compression ring and get it on there without screwing up the boot? I messed with the damn thing for close to an hour with no success.
    Should I maybe try a new compression ring? If so, anyone know where I can get one? Maybe Dave will chime in
    Thanks,
    Andy
    99 GT (Stock - DD) & 04 Comp G (A Few Mods)
  1. Trim piece on my driver's side door broken
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 05-15-2010, 11:59 AM
  2. Replaced pass. halfshaft - what did I screw up in the trans???
    By GTPrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2008, 12:00 AM
  3. trouble installing halfshaft
    By ShouldaGotTheGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-10-2008, 05:14 AM
  4. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
  5. Passenger Side Axle Seal Replacement
    By Rob3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2008, 04:35 PM
