Thread: Driver's side axle / halfshaft issue...
Results 1 to 11 of 11
  1. #1 Driver's side axle / halfshaft issue...
    SE Level Member GrandPrixGT300's Avatar
    Sandusky, OH
    I cannot get the shaft to snap in over the compression ring. The passengers side went on in maybe a minute. I lubed the crap out of the driver side and tried having the ring pointed in different directions to no avail. Anyone have a trick to shock the compression ring and get it on there without screwing up the boot? I messed with the damn thing for close to an hour with no success.
    Should I maybe try a new compression ring? If so, anyone know where I can get one? Maybe Dave will chime in
    Thanks,
    Andy
    99 GT (Stock - DD) & 04 Comp G (A Few Mods)
  2. #2 Re: Driver's side axle / halfshaft issue...
    TDCRacing
    Guest
    It is kind of a pain at times. I guess you could try putting a hose clamp over half of the ring. Then tighten it down. And slip the axle on. Other wise try hitting the end of the axle with the nut on with a 5 or 10 LB hammer lightly. Just make sure you have it ligned up and you should be good.
  3. #3 Re: Driver's side axle / halfshaft issue...
    Banned - Busted For Scamming
    Feb 2009
    i have found that its more of a "shock" that gets those damn things to go in/out. Hit it with a hammer.
  4. #4 Re: Driver's side axle / halfshaft issue...
    TDCRacing
    Guest
    You're exactly right. If you're trying to push it in with your hands just give up now.
  5. #5 Re: Driver's side axle / halfshaft issue...
    Sandusky, OH
    I was able to shove the passenger side back on by hand. So, I need to line up the whole halfshaft and hit it with a hammer? I thought of doing that but didn't want to screw up a joint or something. I still have the hub attached so I'll try that but I won't be able to till friday night when I go back to Fort Wayne again. I'm open to any other ideas. I did have one hell of a time getting it off, I just wish there was somewhere to use the slide hammer to knock it back on.
    Thanks guys.
  6. #6 Re: Driver's side axle / halfshaft issue...
    Feb 2009
    if you cant get it on with the hub attached, take the cv axle off and try to line it up right and push it in that way. Its hard to say, but all the times they are different as far as how hard. Ive had some come right out with no effort and some of them you would swear there is something in the way, but no, it just needed tapped in. So its up to you, but be the judge, obviously taking a ten pounder to it with a full swing is not a good idea. Hope this helps.
  7. #7 Re: Driver's side axle / halfshaft issue...
    Apr 2009
    Springfield,Va
    Swapped mine out over the weekend. Had to pull the strut out and hit it with a hammer to get it to go in. Was overall pretty easy compared to other cars I have worked on.
  8. #8 Re: Driver's side axle / halfshaft issue...
    Sandusky, OH
    Well guys I'm confused now. I can get it to go in and I think It's going over the compression clip but I can pull it back off by hand but it catches a little then comes off like it's compressing the clip. Should I be able to see any of the machined "shiny" part of the axle if it's all the way in? I can't remember how it was when I took it out. it's going in about 1 1/4" so it's gotta be compressing the clip. What do you guys think?
  9. #9 Re: Driver's side axle / halfshaft issue...
    Sandusky, OH
    Alright well I pulled the compression clip off and it will not go in any farther than when the clip is on? Is the new seal maybe different so that's why all the machined "shiny" part of the axle isn't going into the trans? This is the last thing I have to do to fire up the car.
    Andy
  10. #10 Re: Driver's side axle / halfshaft issue...*output shaft backwards?*
    Sandusky, OH
    Well guys, I think I figured out my issues. I'm a dumbass and put the output shaft in backwards. One side has longer splines than the other correct?
    Andy
  11. #11 Re: Driver's side axle / halfshaft issue...
    Sandusky, OH
    Welp it's confirmed, I'm a retard ...haha I had the output shaft in backwards so after swapping it around it went in in about 5 sec...haha
  1. Trim piece on my driver's side door broken
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 05-15-2010, 11:59 AM
  2. Replaced pass. halfshaft - what did I screw up in the trans???
    By GTPrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2008, 12:00 AM
  3. trouble installing halfshaft
    By ShouldaGotTheGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-10-2008, 05:14 AM
  4. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
  5. Passenger Side Axle Seal Replacement
    By Rob3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2008, 04:35 PM
