Thread: 98 gtp help tranny problem
Results 1 to 3 of 3
  1. #1 98 gtp help tranny problem
    Apr 2009
    Mississippi
    hello there i recently purchased this 98 daytona 500 pace car from my dad.he says about 2 months ago he got a SES light and a DTC po102.mass air flow sensor low input. he drove the car with the light on and just recently the tranny started acting up.first a loud whining noise came from it and it stopped shifting.he made it home after a few starts and stops about 5 miles or so down the road.he had to go a few miles and stop and wait then go a few more miles til he made it home.afterwards.he changed the tranny fluid and filter and said it looked ok still red but was sludggy grey lookin.he then drove it about 200 or so more miles not having but one problem when going into 4th gear [OD] it would make a jerky or shimmy at around 45mph.after the 200 or so miles it went down again with a whine and no shift.i bought it,towed it home and checked the DTC's i found theseo102,po141,po742 and po756 i know what they mean i gotta book i would like some help on what to fix i havent dropped the pan again yet but plan to. i tried some Lubegard #60902 and it did nothing.i can start the car the pump whines for about 2 mins. or so and stops then it will not take off in any gear!but when i unplug the MAF sensor the pump whines and the car will move some.i have heard the MAF circuit is tied into the tranny and could cause it to fail.i have planned to replace the TCC solenoid and the MAF sensor and change the tranny fluid and filter but will this help? thanks.
  2. #2 Re: 98 gtp help tranny problem
    Jul 2008
    Germantown, Maryland
    i was having the same problem... replaced the sensor and haven't had a problem
  3. #3 Re: 98 gtp help tranny problem
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    That gray sludgy stuff sounds pretty bad. If the pump was whining, then it probably was a full line pressure and really strains the pump...maybe even wearing it down. With all the metal parts that wear inside a tranny, it's difficult to speculate as to what caused that sludge.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. 01 GTP tranny problem
    By jaegle2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-16-2010, 01:33 AM
  2. 99 gtp tranny problem
    By BRIAN70SS in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2009, 01:10 AM
  3. The tranny problem that can't be figured out
    By Red97GPGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2009, 10:50 AM
  4. Possible tranny problem?
    By isucyclones3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-04-2009, 11:52 AM
  5. Tranny Problem
    By 2000GTP2708 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-24-2008, 02:48 AM
