Thread: 2001 GTP to GT swap - need some quick help
Results 1 to 10 of 10
  1. #1 2001 GTP to GT swap - need some quick help
    Dec 2008
    Willow Springs, MO
    Not sure if you guys remember me, but I'm trying to fix a bad tranny in my 2000 GPgt - it's got 146k
    Anyway, I have the oportunity to buy a side hit 2001 GTP with 128k - the whole car for $500 - still runs good -
    Questions: will the GTP tranny work behind the GT?
    how about swapping both engine and tranny?
    I have to tell them something by the end of the day, so if anyone is listening - thanks for a quick response
  2. #2 Re: 2001 GTP to GT swap - need some quick help
    TDCRacing
    Guest
    Yes it will work.
  3. #3 Re: 2001 GTP to GT swap - need some quick help
    Dec 2008
    Willow Springs, MO
    Thanks for the response. By yes it will work are you referring to the engine/tranny swap or the tranny for tranny swap? Which way is best?
    Thanks
  4. #4 Re: 2001 GTP to GT swap - need some quick help
    TDCRacing
    Guest
    You can swap over the trany from the gtp into you're gt. If you swap over the motor from the gtp without the supercharger it will be slower due to the lower compression in the supercharged motors.
    Best bet is to buy the car. And swap over EVERYTHING. Just swap over the transmission,Axles,Engine harness and the engine and supercharger.
    You'll notice a real nice power increase and you'll have a new and working trans installed.
  5. #5 Re: 2001 GTP to GT swap - need some quick help
    Dec 2008
    Willow Springs, MO
    Ok, I love the idea of some more hp and torque. Especially in a sleeper unmarked GT. I am a little scared of getting in over my head though. Here are some thoughts.
    How much different are the wiring harnesses? Will I have to change the whole thing?
    How many computers boxes do I have to change?
    Will I have to rip the whole dash out of the GT?
    Will the boost gauge be an issue?
    Thanks so much for the help.
  6. #6 Re: 2001 GTP to GT swap - need some quick help
    Dec 2008
    Willow Springs, MO
    Also,
    I forgot to ask about the heads up display in my GT - will that be any prob?
    thanks
  7. #7 Re: 2001 GTP to GT swap - need some quick help
    Barksdale AFB, LA
    If you just do the transmission, you'll need to get the programmed gear ratio in your PCM changed. Otherwise it will have issues. This is not a problem if you take the whole engine, transmission, and PCM/harness. With that, all you have to do is get your VIN programmed into the new PCM.
    Quote Originally Posted by 2000GPGT View Post
    Also,
    thanks
    No. It receives data digitally over the OBD2 bus.
    2009 Subaru Impreza WRX STI
  8. #8 Re: 2001 GTP to GT swap - need some quick help
    Dec 2008
    Willow Springs, MO
    By you saying get the vin programmed - how and who could do that?
    Also does anyone know how big a job it would be to change the harness/computer stuff?
    Will I have to rip the dash out of my old GT?
    thanks
  9. #9 Re: 2001 GTP to GT swap - need some quick help
    TDCRacing
    Guest
    The dealer can or anyone with a tuner can program it in.
  10. #10 Re: 2001 GTP to GT swap - need some quick help
    Dec 2008
    Willow Springs, MO
    Thanks for continuing to help me along.
    I am still wondering about the harness though and how deep I will have to go into the old GT dash with the GTP harness?
  1. new member 2001 gt
    By 01gt in forum Introductions/Noob Questions
    Last Post: 12-25-2008, 03:01 PM
  2. 2001 service manual
    By Jakegday in forum General Tech Discussion
    Last Post: 11-16-2008, 03:59 PM
  3. Getting 2001 GTP in 3 weeks
    By jacobmh27 in forum Introductions/Noob Questions
    Last Post: 03-25-2008, 10:21 AM
  4. Need 1.5 Bin File for 2001 GTP
    By rynoman03 in forum PCM Tuning
    Last Post: 02-20-2008, 01:01 PM
