Thread: switching to dexron VI in an 02
Results 1 to 18 of 18
  1. #1 switching to dexron VI in an 02
    da U.P.
    my sister has an 02 SE and is at 100K, I want to change out the fluid with Dexron VI, it currently has the original Dexron III, can I simply drop the pan, drain what fluid possible, replace the filter and just top it off with Dexron VI? if I do have to flush it out, how do I do this in a driveway?
  2. #2 Re: switching to dexron VI in an 02
    SE Level Member GrandPrixGT300's Avatar
    Sandusky, OH
    From what I've read, just drop the pan and replace the filter, that's the best way to do it especially with that many miles on it. The trans has gotten used to the old fluid and if you flush it, it will kinda "shock" the system.
    99 GT (Stock - DD) & 04 Comp G (A Few Mods)
  3. #3 Re: switching to dexron VI in an 02
    da U.P.
    not that I don't believe you, but I have heard similar opinions on synthetic oil, but at the same time I have seen people change engine oil for synthetic at 100+ thousand miles with no problems. anyone else?
  4. #4 Re: switching to dexron VI in an 02
    da U.P.
    just looked at the transmission fluid and it's terribly dirty, is there a way I can evacuate more than 7.5 quarts of fluid?
  5. #5 Re: switching to dexron VI in an 02
    Barksdale AFB, LA
    I did it by just dropping the pan. It was fine. I'm now on my second fluid change with Dex VI about a year later to help even out the mixture (though you don't have to, I was installing a shift kit).
    2009 Subaru Impreza WRX STI
  6. #6 Re: switching to dexron VI in an 02
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    I added Valvolene Dex VI recently, though, I added 10.5 quarts. I did notice a big difference in temp stability. They say it's backwards compatible.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  7. #7 Re: switching to dexron VI in an 02
    da U.P.
    did you just do a pan drop? if not, how did you get 10.5 quarts out?
  8. #8 Re: switching to dexron VI in an 02
    Dec 2008
    Alabama
    Pan drop and side cover was removed. I had the engine/trans tilted down so the fluid would run out of the clutch/differential area. It sat like that for a couple of months, so it drained out really well. lol
  9. #9 Re: switching to dexron VI in an 02
    da U.P.
    lol, I don't have months. is the side cover obvious? how hard is it to remove, is there anything that will fall out when I remove it? and is there a gasket that will need replacing?
  10. #10 Re: switching to dexron VI in an 02
    GTP Level Member Scimmia's Avatar
    QCA, IA
    You don't want to screw with the sidecover just to get fluid out. You're talking removing the axle, lowering the subframe, etc.
    2001 Buick Regal LS - Almost Stock
  11. #11 Re: switching to dexron VI in an 02
    Dec 2008
    Alabama
    The side cover is obvious, it's a ***** to remove--at least it was in my little engine compartment, nothing will fall out when you remove it, and the gasket is a metal/rubber bonded that is reusable. Not worth it unless you plan on getting deeper into the tranny, like the valve body and channel plate. I had the side cover off since it cracked by the torx bolts. Since I was there, I did a few things. You might be able to jack the passenger side up a ways to promote drainage out of the clutch pack area, and in a couple of days let it back down. Just a thought, not sure that would work, but worth a shot.
  12. #12 Re: switching to dexron VI in an 02
    da U.P.
    once again, the car can't sit, you would think there would be an easy way to do this.
  13. #13 Re: switching to dexron VI in an 02
    Barksdale AFB, LA
    Quote Originally Posted by adamlesandrini View Post
    Most of the remaining fluid is in the torque converter. You won't get that out. Just drop the pan, replace the 8 qts (of the 12 total), and be happy.
  14. #14 Re: switching to dexron VI in an 02
    Dec 2008
    Alabama
    It's either that or find a place that will do a fluid exchange.
  15. #15 Re: switching to dexron VI in an 02
    slc utah
    the next best thing would be dropping the pan changing filter and refill with 8ish quarts and the drive around for 5 miles or so and drop pan and change fluid agian that will help alot with the mixture.
  16. #16 Re: switching to dexron VI in an 02
    Dec 2008
    Alabama
    that's true, but not crucial to do.
  17. #17 Re: switching to dexron VI in an 02
    Nov 2008
    Cedar Rapids, IA
    I sounds like you're really worried about running a mixture of the old Dex III and the new DexVI. Trust us, save yourself the hassle of evacuating every last drop of fluid and just do a pan drop/ filter change. The slight mixture you will have afterwords will in no way cause harm to anything.
  18. #18 Re: switching to dexron VI in an 02
    Dec 2008
    Alabama
    Agreed. No need to sweat it. Dex VI is backwards compatible, meaning you can add Dex VI to Dex III.
  1. What problems come with switching PCM's?
    By gdbyrd in forum PCM Tuning
    Last Post: 03-19-2009, 11:13 AM
  2. Pennzoil Dexron VI
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-29-2008, 08:19 AM
  3. Rough shifting, switch to Dexron VI?
    By Deezul_AwT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2008, 12:20 PM
  4. thinking about switching to 06 monte ss seats
    By s1795so2 in forum Visual/Body Modifications
    Last Post: 01-06-2008, 01:29 AM
