Thread: Transmission cooler setup - should I change it? What temps are too hot?
Results 1 to 6 of 6
  1. #1 Transmission cooler setup - should I change it? What temps are too hot?
    Donating Users Tengis's Avatar
    Houston
    Ive got a pretty decent 26000gvw trans cooler (that Trannyman recommended). I put it here so that the fans sucking through the radiator would also suck through the trans cooler - it also gets air from the passenger side grill. Here is where it is attached:
    My temps get pretty warm when Im doing WOT runs and stay very consistent while Im cruising. At wot the temps go to about 95-100c or 200-210 degrees fahrenheit. After the temp gets up there it usually doesnt come back down unless I do quite a bit of cruising with the TCC locked or I have to park the car and turn it off.
    It takes a long time for my temps to get up to ECT temps so I know the tranny cooler works well. Trans temps at cruise are usually a fairly consistent 80-85 celcius or 180-185 fahrenheit. I just cant keep the temps down while going WOT which brings me to my question:
    Should I get a fanspeed switch from ZZP and turn my fans on when going WOT to cool the tranny cooler?
    Should I get a seperate fan thats activated by the trans temperature? If so, any slim fan with a high flow rate that you guys recommend?
    The trans is being cooled ONLY by the trans cooler - should I route the lines through the stock cooler as well? Would it help any?
    What are acceptable transmission temperatures when cruising and WOT? Ive seen stock trannies get pretty damn warm so Im assuming mine are fine - but Ive always been told the cooler the better.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  2. #2 Re: Transmission cooler setup - should I change it? What temps are too hot?
    Barksdale AFB, LA
    Quote Originally Posted by Tengis View Post
    That might make it worse as the hot coolant in the radiator warms the fluid.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Transmission cooler setup - should I change it? What temps are too hot?
    Moore, Oklahoma
    ttt
    Shawn W. Larsen
  4. #4 Re: Transmission cooler setup - should I change it? What temps are too hot?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    If you have room for a small fan that would certainly help when not cruising down the highway. Your converter must be fairly loose for the temps to sit that hot after a hard run. You can try putting the radiator back in the loop but Im not sure it is going to be of much benifit, but hey if it works it works and if not then you just proved to yourself that it isnt benificial.
  5. #5 Re: Transmission cooler setup - should I change it? What temps are too hot?
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    FYI, my tranny temps and how they react are exactly like yours. I don't have nearly the weight nor the power you do. I had a small B&M cooler, which is a very good cooler, but decided to remove it. I wanted to be sure the tranny warmed up as quickly as possible. It did help to cool down on the highway, but still took a while. I did recently discover that the optimal operating temp for a transmission is about 190*. So, 200* really isn't that bad. I think running through the factory cooler is a good idea. The fluid should run thought the factory cooler last. The engine heats up faster than the tranny. So a hot radiator will help to heat the tranny up fast. With a 180* stat, tranny temp will try to remain around there. Most cars have a 195* stat, so a temp of 200-210 would be totally fine. If anyone is interested, I have the BIG B&M style cooler I would be willing to sell. It measures roughly 11x12x1.5 inches.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  6. #6 Re: Transmission cooler setup - should I change it? What temps are too hot?
    Jun 2017
    Indianapolis, IN
    What is a good cooler to get? Any links to amazon or ebay posts would be awesome? Thank you in advance
  1. Auxillary transmission cooler?
    By keenan00gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2008, 06:35 PM
  2. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
  3. My car temps?
    By getsumbaby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2008, 03:36 PM
  4. Monitoring IC temps
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 09:28 PM
  5. Tranny Temps
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2008, 03:32 PM
