Thread: Trans cooler for GXP
Results 1 to 10 of 10
  1. #1 Trans cooler for GXP
    SE Level Member Rnungaray08's Avatar
    Apr 2013
    Milwaukee,WI
    I want to order a trans cooler before I even start thinking about any other mods. Which ones have you guys use that you recommend?? And also Im thinking of a transgo shift kit as a member recommended to prolong the life of the tranny
    2006 Grand Prix GXP
    Sport Red Metallic, 20% Tint
    Future Mods: Trans Cooler(Ordered)
    CAI, Intune with diablew tune, exhaust
  2. #2 Re: Trans cooler for GXP
    I'd likely see what TripleEdgePerformance.com recommends. Dave and the guys have dealt with a number of GXP's and have experience in the heat issues.
  3. #3 Re: Trans cooler for GXP
    Yoga city
    been told go big and plumb inline, if cold is an issue in your area put a thremostat on it
  4. #4 Re: Trans cooler for GXP
    I live here. DirtDog's Avatar
    Jun 2012
    If u email triple edge performance they have a bolt on tranny cooler that is a complete bypass of the stock radiator that is supposed to be awesome. I plan to order one my self. They sent me pics of if and it has a couple inches between it and the radiator and bolts to preexisting bolts on the frame of the vehicle. I also researched the parts they use to make it and the price they charge is actually good since the weld the fittings and all on.
    Although currently I'm just running two cooler I bought from oreillys
  5. #5 Re: Trans cooler for GXP
    Arizona
    I'm just running one and bypassed factory and it sits in the bumper. It was the rv sized one but I have no issues in Arizona heat and always under 185 degrees. I disagree with leaving the factory one in place at all but that's another story debate. Regardless the coolers you can buy at your local auto parts store will Help
  6. #6 Re: Trans cooler for GXP
    Yoga city
    Not gonna jack the thread at all but I would like to conversation on in-line or not.
    Back to the subject at hand, also have RV size. Not even in yet and rarely see 200 degrees.
  7. #7 Re: Trans cooler for GXP
    Arizona
    I say run standalone for a couple of reasons gxp's thermostat doesn't open till 192 degrees even if you have a aftermarket thermostat the fans will not come on till 192 degrees regardless of tune unless you're running a 2 bar os from HP tuners which only 2-3 turbo guys are running. So you're factory trans cooler is also co located with the radiator Having trans fluid run through it will keep it cooking and not give the fluid a real chance to cool back down before it enters Trans. Then you add another cooler well then the transmission has to Pump more fluid around to the cooler you install which in turn cools a little but it can only do so much. So at that point you're not maximizing your investment in buying the second cooler. Running standalone keeps it efficient without the heat soak and minimizing the amount of fluid having to be pumped around. That's my logic and has worked Well. And for you guys talking about cold weather theory I get it but if you're that guy that likes to do a lot of asshole driving before the car even warms up nothing will save your transmission anyway. And not to mention the transmission has tables already built in for colder weather operation.
  8. #8 Re: Trans cooler for GXP
    Jun 2017
    Indianapolis, IN
    If I have a standard transmission, can I replace it with a HD transmission from triple edge? In doing so will there need to be anything else I need for suck swap out?
  9. #9 Re: Trans cooler for GXP
    May 2017
    Dirtyzville, Mizzery
    Dave's transmissions are top notch.
    I had one in my GXP with all the goodies and 3.69's. Would do it again in a heartbeat. It really woke up the car after the gear and tune. Really helped pull it together.
    The install was a lot more time consuming compared to a 3800 (since they're basically the same transmission)...tons of little clips, a few different brackets, etc.
    However after the install the radiator was bypassed and I ran a Tru-Cool 4590 RV cooler. Never saw temps over 182* even beating the snot out of it on a hot day; completely different from the factory setup with no cooler that would go north of 220* quite often.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  10. #10 Re: Trans cooler for GXP
    Wichita
    Standalone from TEP Helps. But I still sometimes see high temps on hot days w lots of driving.
  1. trans cooler
    By 05ls4gxp in forum 5.3L V8 (LS4)
    Last Post: 02-18-2013, 07:23 PM
  2. how to add a trans cooler
    By DirtDog in forum How To Write-Ups/Tech Tips
    Last Post: 09-17-2012, 08:54 PM
  3. trans cooler and oil cooler
    By mhartwig in forum General Tech Discussion
    Last Post: 11-17-2010, 10:33 PM
  4. trans cooler?
    By boostedgtp2003 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-02-2010, 08:45 PM
  5. GM aux trans cooler
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:32 AM
