HI,
I would like it if any of you could help I have a 98gtp the speedo quit working . I tried a cluster and it still has no speedo I don`t have a shifting problem.
Thanks Mike
HI,
Thanks Mike
The trans works fine and shifts ok but your speedo is the only thing not working correct? Have you tried cruise control? Does the heads up display work if you have it on your car?
