Thread: 2004 Regal trans in 99 GTP
Results 1 to 4 of 4
  1. #1 2004 Regal trans in 99 GTP
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Hi All,
    I recently got my hands on a turbo GTP with a bad trans.My regal which is down for a cam build till spring has a "good" trans basically out of the car. The regal trans does not have the black box on top of the shifter area.The GTP does.
    My understanding is that i can just take the box off the GTP trans and bolt it onto the regal trans and everything will work. can anyone confirm this? I am planning to really get moving on the trans swap this weekend.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: 2004 Regal trans in 99 GTP
    May 2020
    Pittsburgh
    Chats
    From my understanding, it will not work without some major work.
    The pressure control system went from 6(?) solenoids from 97-03, to just 1(?) for the 2004 year. I also believe the bulk connectors and cooler lines are different.
    That's what i learned when doing my swap in my 2000.
  3. #3 Re: 2004 Regal trans in 99 GTP
    hangover park IL
    Chats
    910
    its easier to put an older trans in a newer car but the 04 regal should be the same as an 03 gp, drive by cable TB, and the pressure manifold switch as well. so you can make it work since youll only be editing out some stuff and you can always go to an 03 gtp bin which uses the IMS trans with the 1 switch delted Pressure manifold switch assembly
    ~James~ Psychotic Gearhead
  4. #4 Re: 2004 Regal trans in 99 GTP
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I decided it wasnt worth the hassle to put an iffy trans in the GTP if it wasnt going to be cheap and easy. I bought an overhaul kit with frictions pistons and steels. Im also going to replace all of the bands.
  1. 03 Regal gs trans question.
    By Swiggles in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-10-2017, 08:37 AM
  2. 99 Intrigue trans into a 99 Regal LS
    By buck531 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-13-2014, 08:15 AM
  3. 98 regal GS Trans 93,000 miles
    By TheGerm in forum For Sale - Parts
    Last Post: 04-19-2013, 09:37 AM
  4. 2004 Regal with New Trans
    By MidnightBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2012, 09:34 AM
  5. 00 Regal various issues with trans
    By BillBoost37 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-06-2011, 12:28 PM
