Thread: Cooler lines
Results 1 to 5 of 5
  1. #1 Cooler lines
    Feb 2018
    Canada
    I have an 07 na and it has 200 000kms. The guy before me never changed the fluid so i did it and once it gets hot, it will kick in from a dead stop. I was thinking of adding a tranny line... actually i just ordered it lol. But my question is can i buy a new tranny line for both supply/ return thats like a stub. Maybe a few inchs long instead of buying a whole new line just to cut it. The old one is rough shape.
    And really hoping the cooler will eliminate the hard take off.
    Thanx
  2. #2 Re: Cooler lines
    GTP Level Member
    Oct 2014
    Not that a cooler will not help eventually, that sounds like a forward band going bad.
  3. #3 Re: Cooler lines
    Feb 2018
    Canada
    Thanks for the reply. Do you think a transgo kit would help??
  4. #4 Re: Cooler lines
    GT Level Member mguzzo's Avatar
    Buffalo NY
    lots of things can cause bang-screech. low fluid, clogged filter, PCS, worn input clutch piston....a shift kit is a band aid.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: Cooler lines
    GTP Level Member
    Oct 2014
    Do those other things but a trans go kit helps firm up the shifts.
    My 08 did a couple slip bangs at 160000 and I figured soon would need a rebuild. I changed the fluid and filter added lubeguard red a shift kit and drove it like a grandma. I would also change the tranny fluid and filter and a bottle of lubeguard red every 30k and it is still rolling at 226000.
    Still figure it could go any time but the slip bang’s disappeared.
  1. Need trans cooler lines ...
    By Le Patriote in forum General Grand Prix Discussion
    Last Post: 02-28-2015, 07:21 AM
  2. cooler lines
    By dlk in forum General Grand Prix Discussion
    Last Post: 01-06-2013, 08:21 PM
  3. Cooler Lines
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2012, 02:50 PM
  4. Transmission Cooler Lines
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2010, 08:53 AM
  5. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
