Thread: Time for a replacement
Results 1 to 2 of 2
  1. #1 Time for a replacement
    May 2020
    Pittsburgh
    So, the other day i'm driving home from work and lean into the throttle to downshift up a hill, hear a small metallic *TINK* followed by a quick climb to redline... but hey, 220k miles, the last 120k tuned, and definitely not used gently, i'm in no way surprised with the failure. I believe the use of an oversized trans cooler and regular services helped this... i digress.
    Reading up on TEP website leads me to believe i lost the forward apply band. I limped it back to work in 1st&2nd gear, and now am finding my replacement.
    I want to change to 3.29s, and it seems i cannot go with a 04+ trans, but a NA 3.29 97-02 trans should work, correct? I have HPT and no issue retuning for ratio correction.
    As far as HD to non-HD, there are minimal differences, as far as I can tell... right?
    Isn't one axle different? Do the cooler fittings swap? Does either one have LSD?
    Anything I should look out for or prepare for? I plan on flushing the cooler, and changing their filter. and rear main/engine oil pan gasket while i'm that far.
  2. #2 Re: Time for a replacement
    May 2020
    Pittsburgh
    After a rather long and tedious day yesterday, the swap is done.
    02 NA 3.29 trans, swapped my HD diff. I still need to re-tune for the ratio change, but HPT was being an ass because i didn't have wifi in the shop.
    Decided to go out the bottom, since i have access to a lift and engine support tools.
    First impression is that it drives incredibly smooth, and i have been overlooking the effects of mileage on my trans. I only drove it 6mi very gently, but it gave no indication of any issues.
    Threw in some pictures to show the process a bit. New trans, broken band, diff comparison...
  3. Thanks hijanek thanked for this post
    Likes hijanek liked this post
  1. Aftermarket Stereo Install? (First Time Grand Prix Owner/ First Time Forum User)
    By Kickflip Supreme in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2015, 08:58 PM
  2. Rack and Pinion replacement time.......
    By traildog in forum General Tech Discussion
    Last Post: 03-10-2014, 07:12 AM
  3. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  4. Long time owner/first time poster!
    By brez in forum Introductions/Noob Questions
    Last Post: 08-08-2011, 04:58 PM
  5. Time For Hub Replacement?
    By ljmonnin12 in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2011, 08:07 PM
