Thread: Authenticity of a 1” GMR Chain
Results 1 to 13 of 13
  1. #1 Authenticity of a 1” GMR Chain
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Can someone please tell me how to correctly measure a real 1” gmr chain? In comparison to let’s say a 15/16”? These made by borg? Any help Is appreciated.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Authenticity of a 1” GMR Chain
    hangover park IL
    the GMR in front of me is a Morse (on link plates) hy-vo with a squirrel figure in profile after the vo (this may be a batch demarcation)
    046 74607 is on the dark blue link. chain measures 1.060 OD from outer guide plate to outer guide plate .940 across the id
    ~James~ Psychotic Gearhead
  3. #3 Re: Authenticity of a 1” GMR Chain
    Nebraska
    Thank you!
  4. #4 Re: Authenticity of a 1” GMR Chain
    May 2008
    Schuyler, NE
    A 1" open end wrench will not fit around a 1" chain. But it will fit on the 15/16 and 7/8.
  5. #5 Re: Authenticity of a 1” GMR Chain
    Nebraska
    I received the chain today it does appear to be an authentic chain but it was sold to me as new and was wondering what you guys thought and how much play a new gmr would have between links. Also seems to have wear marks on one side.
    8297-ECE0-1-D3-A-445-F-8-B54-8-B7-D453358-D7 — ImgBB
    5099-EEC4-8-D89-432-A-A6-E5-95-A8968-BC944 — ImgBB
  6. #6 Re: Authenticity of a 1” GMR Chain
    Nebraska
  7. #7 Re: Authenticity of a 1” GMR Chain
    May 2008
    Schuyler, NE
    The on
  8. #8 Re: Authenticity of a 1” GMR Chain
    May 2008
    Schuyler, NE
    Whoops. The only way you can check wear is by installing it. The manual has a procedure for it with the chain installed.
  9. #9 Re: Authenticity of a 1” GMR Chain
    hangover park IL
    the wear is from the links contacting the ISS tone wheel under heavy IS loading (slip n grip traction event at high power)
    probably should sell the TR's 2.93 1" GMR
  10. #10 Re: Authenticity of a 1” GMR Chain
    Nebraska
    Do you see this chain any weaker or would have any problems holding 650-700whp?
  11. #11 Re: Authenticity of a 1” GMR Chain
    hangover park IL
    oh it'll hold, it still destroys the tone wheel/ISS sensor but the chain survives.... but your still pulling it apart....
    the 7/8ths will handle 700whp...provided you dont slipngrip.
    11 times we've broke transaxles. dyno's at 608fwhp e85 18psi. this last time we broke it was at 28psi and we spun the slicks at 105mph. IFR shows we woulda been at 700+ whp at the slipngrip
  12. #12 Re: Authenticity of a 1” GMR Chain
    hangover park IL
    quick pic fer ya
    GMR 1inch, GMR 2.93 sprockets (from statama bftgt), GMR armet 100 IS
    7/16ths pitch 4t80e stuffs above it....
    enjoy the GMR Pr0n
    GM Racing GMR 1 inch chain and 2.93 sprockets, 1200hp GMR IS, 4t80e chain above - Google Photos
  13. #13 Re: Authenticity of a 1” GMR Chain
    hangover park IL
  1. 1in GMR Chain
    By ADrugDealer in forum For Sale - Parts
    Last Post: 07-14-2014, 09:19 AM
  2. Single 1" chain vs double 1/2" chain
    By Kyne in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 11:58 PM
  3. Chain
    By Iceman6669 in forum General Grand Prix Discussion
    Last Post: 07-23-2013, 09:58 AM
  4. GXP Chain
    By 3800seV2.0 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2008, 09:28 AM
  5. gm 1 in chain
    By kevlws23 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2008, 01:36 AM
