Thread: 04 GTP to 02 GTP transmission conversion
Results 1 to 4 of 4
  1. #1 04 GTP to 02 GTP transmission conversion
    Jan 2018
    US
    Need as much info on this subject as possible. I know the pumps, mode switches, manifold pressure switches & pressure control solenoids are different.
    1. What else am I missing?
    2. Are the Valve Bodies different?
    3. Are the Valve Body Gaskets different?
    4. Are the Channel Plates different?
    Sent from my SM-N950U using Tapatalk
  2. #2 Re: 04 GTP to 02 GTP transmission conversion
    Jan 2018
    US
    Obviously since the MPS's are different, the valve body's are different but more concerned about the VB to CP gaskets.
  3. #3 Re: 04 GTP to 02 GTP transmission conversion
    St. Louis
    I'd double check the gear ratio between the 2. Also, is the 04 trans from a Comp G? I know the tapshift stuff is a completely different animal.
  4. #4 Re: 04 GTP to 02 GTP transmission conversion
    Jan 2018
    US
    Quote Originally Posted by FordMan77 View Post
    Yeah, both MN7 stock Supercharged 2.93 gear ratio.. No tap shift for the 04 Trans
  1. 04+ power passenger seat conversion/ driver's fold conversion
    By wstefan20 in forum General Grand Prix Discussion
    Last Post: 04-04-2020, 01:15 PM
  2. RWD conversion with gto possible ??
    By 504Quan in forum Off Topic Discussion
    Last Post: 05-28-2016, 11:22 AM
  3. HPT to DHP conversion
    By DJNight2k in forum PCM Tuning
    Last Post: 11-02-2012, 07:02 PM
  4. Conversion
    By Nathan07GP in forum Introductions/Noob Questions
    Last Post: 03-06-2012, 01:56 PM
  5. Transmission conversion?
    By JoelsGTP51 in forum Off Topic Discussion
    Last Post: 07-18-2011, 05:47 PM
