Thread: ZZP VS TransGo Shift Kit
Results 1 to 5 of 5
  1. #1 ZZP VS TransGo Shift Kit
    Apr 2012
    North Dakota
    So I have the dreaded P-1811 Code. Which shift kit is better? The Transgo comes with seals but is more expensive while the ZZP only comes with the spacers. I was thinking about just going with the TransGo figured I would post on here first and see what the forum has to say.
  2. #2 Re: ZZP VS TransGo Shift Kit
    St. Louis
    Well, IIRC the ZZP kit is just that- a shift kit that you can install to adjust the shift points and harshness of engagement. I think the one from Trans-go is just used to improve failing parts and keep the shift points where the ECU wants to see them thus reducing/eliminating the P1811 issue. I had this code on my 00 GT and installed just the new accumulators and whatnot from the TransGo kit from Dave at tripleedgeperformance.com and the trans hasn't shifted hard or set any codes since that time, and it's a high mileage trans at that. It does shift a bit more firm but it's never going to bark the tires, which is a good thing. Your call I guess.
    Transgo SK4T65E Shift Kit This is the kit I bought/used.
  3. #3 Re: ZZP VS TransGo Shift Kit
    ive got a full transgo kit in my tranny, installed when it was rebuilt. shifts like a beast. caught a chirp on cam at the track.
    zzp is plastic parts, transgo is not plastic.
  4. Thanks wowitsfast thanked for this post
  5. #4 Re: ZZP VS TransGo Shift Kit
    Apr 2012
    North Dakota
    Thanks for the quick response guys. I just can't believe this transmission is having an issue. About half of its life has been on an interstate at 80 mph. I will have to order the transgo thanks for the help!
  6. #5 Re: ZZP VS TransGo Shift Kit
    Jul 2017
    macomb mi
    id get the transgo with springs spacers and seals I have the zzp and although I haven't had any issues with it I wish I would've just got the the whole transgo kit droping the pan changing the filter, removing the part that holds the springs and valves and filling everything back up is a lot of work to just put spacers in when you can change the springs and seals as well no extra work involved especially if youre a highway driver like me im sure your car has plenty of miles like mine haha and im not sure what your trans runs at but mine was very hot on the highway above 220 going 70mph so I installed a trans cooler and made a huge difference made the trans hesistate MUCH LESS and it runs at 170 now I would do that too while you have the fluid out maybe fresh lines as well depending on mileage my lines went at around 140k miles
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  1. KR after Transgo shift kit
    By sagillman in forum General Tech Discussion
    Last Post: 10-08-2015, 01:46 AM
  2. Can I still put a Transgo shift kit in?
    By Jonarin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2015, 12:13 PM
  3. ZZP Trans Pan + TransGo Shift kit
    By nos4blood70 in forum For Sale - Parts
    Last Post: 01-22-2015, 09:35 PM
  4. LF: Transgo Shift Kit
    By blackthunder in forum For Sale - Parts
    Last Post: 07-10-2014, 11:19 PM
  5. Transgo Shift Kit-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 01:18 PM
