Thread: 4T65E TCC Surge
Results 1 to 3 of 3
  1. #1 4T65E TCC Surge
    Oct 2018
    OH
    I have a '01 GT with 140K that lived most of its life driven by a grandma that's now in assisted living. It's had an easy life. I bought it a few months ago and have serviced EVERYTHING. I also drive this car very easy.
    It runs and drives perfectly, except...I'm beginning to experience mild surging in 4th with the TCC locked. Other than this, it shifts and drives perfectly. I understand this is a common issue. I'd like to correct it before it gets worse. My research has suggested that I should replace the following
    1. PCS
    2. TCC solenoid
    What about these items?
    3. Sonnax TCC Apply Valve Kit 84754-43K
    4. Sonnax Regulator Apply Valve Kit 84754-34K
    5. Both shift solenoids
    6. 4th clutch hub
    7. Hardened 4th shaft (cookie cutter)
    8. Pump shaft
    9. Channel plate gaskets
    The moral of the story, I want to do it right and fix any weak links while I'm in there. It's not worth trying to save $100-$200 and risk having to do the work all over again.
  2. #2 Re: 4T65E TCC Surge
    Oct 2018
    OH
    Anyone?
  3. #3 Re: 4T65E TCC Surge
    Surging could be ignition related etc. Tough to tell you what to do without proving what is actually going on.
    If you are going to have the trans rebuilt, then yes.. do all the upgrades and ensure where ever you have the work done checks clutch basket clearance and doesn't just drop in the standard number of plates/clutches that gm has in the book.
  1. Surge at WOT
    By doug g in forum General Grand Prix Discussion
    Last Post: 04-11-2012, 02:41 PM
  2. RPM Surge
    By whiteknuckle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2011, 10:58 PM
  3. Say no to surge
    By Switzersland in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-10-2011, 10:29 AM
  4. Rpm surge help??
    By Darkcelle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 04:13 AM
  5. RPM surge at start?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-07-2008, 06:24 PM
