Thread: Pan leaking
Results 1 to 20 of 40
  1. #1 Pan leaking
    Oct 2017
    South Jersey
    Has anyone had extensive issues when their pan leaking? Bolts all tightened to each time with a torque wrench, I've leaked through a cork gasket and even the felpro one. Fluid is dripping from two different spots on the pan.
    Sent from my Pixel 2 XL using Tapatalk
  2. #2 Re: Pan leaking
    Not really. Although I don't like the gaskets that don't look like stock. The stock gasket has metal built in and is reusable for life as long as it looks good.
    What torque value are you using? Spec is 10ft lbs or 120 inch lbs.
  3. #3 Re: Pan leaking
    Oct 2017
    South Jersey
    That's what it is, it's the felpro one. And yes 10 pounds
  4. #4 Re: Pan leaking
    HUDSON
    I had this problem on my 2000 GTP too. The oil pan bolts get wet and have drops of oil on them. I upgraded to the aluminum pan that has a simpler engine mount design, and uses just a bead of silicone between the block and pan surface, much better than the over deigned and under performing stock gaskets.
  5. #5 Re: Pan leaking
    Quote Originally Posted by QUICKSILVER462 View Post
    good info for a oil pan. his trans pan is leaking.
  6. #6 Re: Pan leaking
    HUDSON
    Oh, thanks, didnt see that, der!
  7. #7 Re: Pan leaking
    St. Louis
    The only time I've had this issue is when the pan wasn't completely flat along the sealing edge.
  8. #8 Re: Pan leaking
    Oct 2017
    South Jersey
    Quote Originally Posted by FordMan77 View Post
    How would my transmission pan warp?
  9. #9 Re: Pan leaking
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by blueanchorgtp View Post
    From being torqued tight, and during removal. Lay a straight edge ( metal ruler ) along gasket surface, bolt holes usually pucker in a little. Hammer & dolly them flat B4 re-install.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  10. #10 Re: Pan leaking
    Donating Users GaGTPGuy's Avatar
    Feb 2019
    Ga
    I just installed a new pan (AC Delco) and gasket (neoprene with metal insert). It is leaking slightly in certain areas only. I torqued to 5 ft.lbs and then 10 ft.lbs to be sure. Should I snug up where its leaking. My fear is that it will not help. Any suggestions?
  11. #11 Re: Pan leaking
    what part is leaking?
  12. #12 Re: Pan leaking
    Feb 2019
    Ga
    It is along narrow side of pan.
  13. #13 Re: Pan leaking
    Feb 2019
    Ga
    I altered torquing by working from center moving outward along pan
  14. #14 Re: Pan leaking
    Feb 2019
    Ga
    It has been about a week since it was installed.
  15. #15 Re: Pan leaking
    if you have a dot of oil on the bolt heads, along the side of the block, take them out one by one, then clean them off and bush on some pipe thread sealant on the threads, should fix ya up.
  16. #16 Re: Pan leaking
    Feb 2019
    Ga
    One by one and then retorque?
  17. #17 Re: Pan leaking
    or just make em up tight. never went with a tq wrench on them. german spec goodentight. snug then a 1/4 turn more or so. you know till its tight, not bolt breaking tight.
    or re tq em lol what ever you like.
  18. #18 Re: Pan leaking
    Feb 2019
    Ga
    Should I apply pipe thread to those not leaking too? Is that the same as loctite?
  19. #19 Re: Pan leaking
    and i would seal all of them on both sides. the threads go through the block and oil splashes on them then the oil leaks out the treads. the two ends are sealed off, aka timing cover area and rear part by the tranny. so just the sides, its do able.
  20. #20 Re: Pan leaking
    this stuff. with PTFE
  1. Car leaking, not sure from where.
    By 04trbogp in forum General Tech Discussion
    Last Post: 05-25-2015, 10:20 PM
  2. Oil Leaking
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2014, 08:53 PM
  3. what is this? its leaking
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2013, 12:03 AM
  4. Leaking on the top
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 07:23 AM
  5. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
