Thread: 4t65e Strange gear selector issue
Results 1 to 3 of 3
  1. #1 4t65e Strange gear selector issue
    Dec 2021
    Ohio
    I have a 4t65e in a 2007 impala ss(5.3L LS4) I have rebuilt the transmission, the car does not register park on the dash therefor the car does not start in park(will start in neautral) but as well as this the gears on the selector seem to be off by a half of a gear. Reverse is in between park and reverse, neutral is between reverse and neutral ect all the way down to 1st gear. I have a sneeky feeling the two are related. (On a side note I am pretty mechanicly inclined so dont be afraid to lay it on me) Any help is very appreciated. TIA
  2. #2 Re: 4t65e Strange gear selector issue
    St. Louis
    Is the external range selector installed correctly?
    I found this older thread that might help give you some ideas. Gear selector is a gear off after rebuild
  3. #3 Re: 4t65e Strange gear selector issue
    Dec 2021
    Ohio
    07 Has an internal range switch that I never removed( I left the shift lever in during rebuild).
  1. Transmission gear selector rod question
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2015, 02:09 PM
  2. Problems with gear selector switch
    By Jordanmccarty in forum General Tech Discussion
    Last Post: 03-02-2012, 07:24 PM
  3. Gear selector lights
    By Freimuth in forum General Tech Discussion
    Last Post: 09-15-2011, 09:13 AM
  4. Strange 2nd gear issue/Scan Tool Advise
    By Higgins428 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:17 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
