Thread: An early Christmas gift from my Transmission
Results 1 to 6 of 6
  1. #1 An early Christmas gift from my Transmission
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    I was finally able to log in
    The other day I performed a pan drop and shift kit install on my 40th anniversary GTP that has only 56k on it.
    I found this little guy on my magnet:
    Its a spring pin. And only half of it was there. I cracked open the filter and there wasnt really anything at all in there.
    The only thing I found was that it possibly could be the spring pin that holds in the roll pin inside the differential.. I personally have not done any burn outs or anything with it. The owner before me was a middle aged woman and I got the sense that her 'boy thang' mightve been a little aggressive with it from time to time.
    Thoughts?
    2002 Pontiac Grand Prix GTP
    2006 Pontiac GTO LS2 M6
  2. #2 Re: An early Christmas gift from my Transmission
    HUDSON
    That defiantly looks like the differential roll pin.
  3. #3 Re: An early Christmas gift from my Transmission
    May 2013
    Buffalo, NY
    Is this something that needs fixed? Will the roll pin stay in its spot? Its just a summer car so maybe over winter I will pull it apart.
  4. #4 Re: An early Christmas gift from my Transmission
    yes.. go to a junkyard and get a diff from another GTP and then put it into yours. Because after that pin breaks the main diff pin starts walking and chews up the diff cover. When it gets bad enough it either wears through, self destructs or breaks the diff cover. By replacing it, You'll avoid all that.
    ps. wipe the metal dust off the vss while you have the cover in your hand.
  5. #5 Re: An early Christmas gift from my Transmission
    May 2013
    Buffalo, NY
    Sounds like I'm going to have some fun lol. Ugh
    Im I going to have to drain the fluid out of the pan again?
  6. #6 Re: An early Christmas gift from my Transmission
    the saga continues for you. Want to buy an HD diff and cover for dirty cheap? I am doing a swap on an 06 HD and won't need the old diff. It has 93K on it and the trans failed from being totally full of clutch material, no chunks.
    I pulled it.. looks nice. LMK if you want it.
  1. possible birthday gift to myself and 1 definate gift
    By kkehlet in forum Visual/Body Modifications
    Last Post: 01-02-2015, 02:56 AM
  2. How early is too early for a new vehicle?
    By GrandprixGT01 in forum Off Topic Discussion
    Last Post: 05-12-2012, 10:08 AM
  3. Got an early Christmas present!
    By 04BlackComp_G in forum Off Topic Discussion
    Last Post: 12-27-2010, 12:34 AM
  4. My Christmas Gift to all you DVD Lovers
    Last Post: 12-27-2007, 06:37 PM
  5. Christmas came early last night!
    By Abrasive in forum Brakes/Suspension/Chassis
    Last Post: 12-25-2007, 10:50 PM
