Just bought a 2003 aztek for $400 with a bad transmission. It was rebuilt by certified transmissions three years ago and it will upshift fine, but once you remove your foot from the gas, it completely disengages like it's in neutral. Once you come to a stop, it will engage again until you let off the gas again. Haven't dropped the filter yet but my guess is the torque converter which requires a full rebuild. Just wondering if anyone has come across this issue on a new rebuild. Only codes are rear o2 sensor and oil pressure switch which should be unrelated. There is some electronic issues associated with the bcm but shouldn't affect the transmission. Any advice is appreciated!
