Thread: No clue what's going on...
Results 1 to 4 of 4
  1. #1 No clue what's going on...
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I hv an 08 base na 245 kms. I just showed a 420 code for cat and I erased the code 3 times but it don't take long to come back and haunt the dash. I changed the cat out about 18 months ago with a walker cat. Seems to me it's a bit excessive to have one last that long. Unless there's something killing it. My icm went on it after it was installed. One thing I've never been able to do is wot from a stop, it just hits the rev limiter in first til I left off completely and get back on it. It did that from day one at a year old when I got it. Couldn't beat a tractor if I tried lol. No codes ever showed up besides 420 and slow evap leak which was the gas cap.
  2. #2 Re: No clue what's going on...
    Nov 2011
    north bay, ontario
    And every once in awhile I get the dreaded slip when taking off from a dead stop. I wonder if a transgo would help and eliminate the shift problem. I'd hate to replace her
  3. #3 Re: No clue what's going on...
    May 2017
    Dirtyzville, Mizzery
    Sounds like the trans/torque converter is hurting.
    MAF could be an issue, too.
    Fix the EVAP solenoid and put a new gas cap on it.
    Did you put new o2 sensors in when you replaced the cat? If not, do that. Probably needs new plugs/wires too if the cat was plugged up...but with all the random sh1t you're describing it sounds like there is quite a bit going on.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  4. #4 Re: No clue what's going on...
    Nov 2011
    north bay, ontario
    I didn't change the o2 sensors when I changed the cat. Guess I should have. Plugs i put in were iridium about 60 000 kms ago,w ires are about 2 years old.When I'm driving at any speed and holding that speed, the engine Pulsates but not enough for the tach to register. I remember changing out a black plastic cup behind the gas cap. Maybe I should order some parts from rockauto I guess. Oh, 2 months ago I changed lim gasket and instead of using a torque wrench I just tightened em all up pretty snug. Should i redo this? Somethings telling that my pulsating engine is from my stupid lim job that i torqued down. ĐAnyone elsez gp do that from a dead stop to wot and first gear just wind out til you left off. Thanks
  1. very weird problem....i dont have a clue
    By genocide in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-02-2022, 06:39 PM
  2. I have no clue what i just did but .......
    By GTPAIELLO in forum PCM Tuning
    Last Post: 12-08-2012, 09:35 AM
  3. Any clue what brand belt this is?
    By kyle91 in forum General Tech Discussion
    Last Post: 08-12-2011, 08:18 AM
  4. General problems? No clue about GM's...
    By PowerStroker in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-30-2009, 01:58 AM
  5. anyone have a clue?
    By gtpinsc in forum Audio, Security & Visual Electronics
    Last Post: 12-17-2008, 06:25 PM
