Thread: P1811 max adapt, long shift
Results 1 to 8 of 8
  1. #1 P1811 max adapt, long shift
    Aug 2017
    Utah
    Ok, so I have a 2001 Grand Prix GT with the 3.8 and the 4T65E tranny and it's throwing the P1811 code. The symptoms have been present since I bought the car almost 3 years ago at around 188K miles (now 217K) the car shifts fine and grabs fine in cold weather and even in hot weather up until it heats up. In winter when it's cold the symptoms almost never happen, it's rare, but in hot weather during the summer the problem is ever present especially once the car heats up. It shifts hard between all gears, shifting up and down. However before the car heats up in the summer the shifts are smooth but long which is what is causing the tranny to max out line pressure and throw that code. I changed the fluid twice (within a two week period to be sure I got all the crud out of the system) and replaced the filter about 25K miles ago (a little after I bought it) and the fluid wasn't too terrible, considerably dark, maybe a brownish maroon and just a tiny bit of build up on the bottom of the magnetic pan. Tranny fluid now is still a shade darker than new and no build up or anything on the dipstick. I've read a ton about this code and that the PCM (pressure control module) could be the problem. Tons of people having the same symptoms and saying that replacing the PCM has basically solved all the issues, however I'm also reading that replacing it isn't a gaurunteed fix which I'm fully aware of, especially with how long I've let this problem go thinking the transmission was just going out. I want to just have a shop replace the PCM and I hope that fixes the problem however the one thing I am concerned about is that during the summer especially, from a stop if I give the car too much gas it shudders pretty bad and feels like clutch slippage, (sometimes no slippage at all, still more often than not.) and every now and then the shifts aren't hard it just shudders between the shift which makes me think the clutches are in fact worn and tranny might just need to be rebuilt. I am wondering if there is any correlation between this specific symptom and the P1811 code. Like if it's possible that the bad PCM could not only be causing hard shifts but could also be causing clutch slippage of any kind. I realize the car has a ton of miles and a rebuild would in fact be the best thing regardless of what's wrong with the PCM. I just don't have the money to spend on a new tranny or a rebuild, especially since the cost of either is more than the car is even worth at this point. Any information or input from someone who knows better would be much appreciated.
  2. #2 Re: P1811 max adapt, long shift
    I would do a shift kit before I thought the PCM was the issue. I doubt replacing the computer would do anything.
    http://www.tripleedgeperformance.com...ift-P1811.html
  3. #3 Re: P1811 max adapt, long shift
    Aug 2017
    Utah
    maybe I was referring to the wrong part, I think it's the valve im talking about not the computer. I think. Not completely sure
  4. #4 Re: P1811 max adapt, long shift
    Aug 2017
    Utah
    Hmm actually now that I'm looking at shift kits for this transmission it's showing that it helps fix all the issues I'm having, maybe a shift kit would be the best solution. Would the transmission have to be disassembled to put it in? Or just have to drop the pan?
  5. #5 Re: P1811 max adapt, long shift
    if it shutters off the line it need to be rebuilt. after a fluid change for the shift kit it might not even move.
    id dump a qt of some kind of trans medix and baby it till you can afford a tranny.
  6. #6 Re: P1811 max adapt, long shift
    New York
    You might want to read :
    4T65E Hard Shift-Solution
    Thread in this section.
  7. #7 Re: P1811 max adapt, long shift
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Chances are that if the PCS solenoid, or any of the solenoids failed, the trans will need more parts than a shift kit due to wear caused by the condition.
    I think the service life or interval on these is ridiculously low mileage anyway. Can't remember where, but I read something like that a long time ago.
    Probably just take it easy like Scott said.
  8. #8 Re: P1811 max adapt, long shift
    Jul 2010
    Coquitlam,BC,Canada
    IMO, install a shift kit and see what happens. Odds are she'll shift ok. If she does, enjoy it and change the fluid regularly. If you see hi temps, add a cooler in.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. shift kit question Throwing code P1811
    By knightryda01 in forum General Tech Discussion
    Last Post: 03-17-2015, 12:36 AM
  2. Intermittent Max Adapt Hard Shift
    By Chadgervais in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-15-2013, 12:41 PM
  3. 2005 Grand Prix 190,000 miles P1811 max adapt and long shift
    By PixelMagic in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2013, 07:23 PM
  4. p1811 max adapt-long shift
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2008, 03:21 PM
  5. P1811 code (maximum adapt and long shift)
    By DuBob in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 09:46 PM
