Has anyone changed the transmission gear ratio on a 2007 transmission?? Will I be able to program it in fine with the 07 pcm with HPT??
Ok thanks. You wouldn't happen to know of any links that show this procedure? Dave is getting ready to build my transmission and wants to know what gear ratio I want.. What ratio would you recommend. Would 3.69 be good or should I go lower 3.29 or stock?
Thanks for the help 5FDP!!
I will get the 3.29s then
