Thread: Tranny question, sun gear shaft
Results 1 to 10 of 10
  1. #1 Tranny question, sun gear shaft
    May 2017
    Michigan
    Tried posting this once with tapatalk and it crashed.
    Long story short. 4t65ehd, forward band broke. Didn't pull tranny dong it in car. An idiot i had in the garage pulled the final drive sun gear shaft, not sure how he mustive broke the c clip.
    What are the chances of getting it to seat properly without pulling the diff?
    I have lots of pics can't upload them, and photobuckets g9ving me issues.
  2. #2 Re: Tranny question, sun gear shaft
    Mar 2017
    Internet
    What sun gear shaft?
    The correct way to put a trans together is to put the diff/sun gear in and install all the other stuff. then you put the uh... kripes I'm forgetting names... main shaft into the trans. One tap and it's in.
  3. #3 Re: Tranny question, sun gear shaft
    May 2017
    Michigan
    Thanks for the reply.
    Didn't need to pull the output shaft (what you're probably thinking) didn't need to touch the diff.
    If I could upload the pics it's easier to understand.
    I'll try to explain with phone and fat fingers.
    This can be done with tranny still in car. Pull everything from driver side, pull dogbones and lower cradle.
    Pulled sidecover, vb, everything down to chain, pulled chain, then started pulling everything oit, inspecting and setting in order each piece. Output shaft doesn't need to be pulled. I pulled everything down to forward band, which was broke,
    The manual calls this piece the final drive sun gear shaft, it shouldn't even come out without the diff off as the manual shows and clip that holds it in.
    I had an idiot in my garage that not only screwed with the parts and got them out of order forcing me to waste hours and money on the tech manual to figure it out (I do everything but trannys hate them, first time diving into it and will be the last, I see why labor is expensive)
    While I wasn't paying attention somehow he forced it out, I've got it back in, it's in there where it moves out about a quarter inch then stops unless you use force to pull.
    Like I said it's better with pictures to show how far it's in and what it looks Like, but I can't upload them, to big.
    Manual shows this shaft being worked on and coming out the diff side so I'm assuming I can reassemble everything and worry about the clip later? The shaft is not flush with the tube inside there
    Having this shaft pulled has got me in a very bad mood, people know not to touch my stuff or what I'm working on and this is why.
  4. #4 Re: Tranny question, sun gear shaft
    Mar 2017
    Internet
    Jump in the chatbox Ask Scottydoggs for the link to the dropbox In it is the rebuilt manual for the transmission. I think that's about all you need
    But then you say you have the manual.
    Can't quite think of which clip you are talking about. Do you have a pic?
  5. #5 Re: Tranny question, sun gear shaft
    drop bon is a sticky in the tuning section.
  6. #6 Re: Tranny question, sun gear shaft
    Mar 2017
    Internet
    ty spuge
  7. #7 Re: Tranny question, sun gear shaft
    May 2017
    Michigan
    Here's a pic of the manual, you have the shaft 689 in the right figire, the bottom left figure you have the clip 512.
    Still not sure how it was pulled out like it was, I'm thinking the idiot broke the clip
    Tranny question, sun gear shaft Attached Images
  8. #8 Re: Tranny question, sun gear shaft
    May 2017
    Michigan
    Here's what it looks like, don't think it's in all the way as I can't get the oil dam over it.
  9. #9 Re: Tranny question, sun gear shaft
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    The clip 512 is on the output shaft. There is no clip on the sun gear shaft. I believe the sungear shaft has 2 flat spots on it though that need to line up with spots on the diff gear. If you pull the differential you can get to the gear and shaft from that side. Also need to ensure the park gear and bearing are all still aligned on the shaft as well.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  10. #10 Re: Tranny question, sun gear shaft
    Mar 2017
    Internet
    You should not have the output shaft in at this point. It's the last step to assembling a transmission. Grab the manual from the dropbox because it gives you step by step.
  1. kr from removal of balance shaft gear
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2016, 10:59 AM
  2. should i get rid of my balance shaft gear with a vs cam?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2013, 02:56 PM
  3. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  4. half shaft / tranny question - looking at a car to buy
    By EternalX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2012, 07:30 AM
