Thread: Transmission overheating
Results 1 to 14 of 14
  1. #1 Transmission overheating
    Jan 2017
    North Carolina
    Hello guys. So while driving in town I notice my transmission fluid jumps from 79 degrees and will go as high as 196 in as little as 30 minutes but it doesn't happen all the time. I have read suggestions to add a coolant line or turn on the AC. What should I do? I have a 2004 GP gt no turbo.
  2. #2 Re: Transmission overheating
    Nov 2012
    Madison
    well ya know there is the transmission cooler idea.
    Other than that the temps are normal.
  3. #3 Re: Transmission overheating
    Anything under 210-215 isn't really a problem.
    The ideal temp is 175-195ish for long fluid life.
  4. #4 Re: Transmission overheating
    Jan 2017
    North Carolina
    I am a new car owner but this temperature worries me. I'm taking my car to the shop tomorrow and I will run the coolant idea by them. I also know the fans aren't cutting on until it hits 200. How have you guys overcome that problem?
  5. #5 Re: Transmission overheating
    What problem?
    That is how most cars are all designed.
    95% of cars made run a coolant temp of 190-210 depending on model from the factory, they all try to run the same-ish transmission temp and oil temps. Both of those around 200, one for long fluid/oil life and two to help burn off condensation that builds up on the motor/transmission.
    Here is a good chart to go off of for transmission temps.
  6. #6 Re: Transmission overheating
    Jul 2010
    Coquitlam,BC,Canada
    Tranny cooler is your only fix, or do regular fluid changes. In the summer, I see temps of 205-215 within 20-30 minutes of driving on the freeway.
    This one was even more exciting. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Transmission overheating
    Cooler isn't needed at those temps. Cooler than 180-195 isn't good for the trans either. Lower than that.. you aren't warming up enough.
  8. #8 Re: Transmission overheating
    Jul 2010
    Coquitlam,BC,Canada
    The problem for me is the temp just keeps climbing. To get to 220* after 60 minutes of driving, and 30 minutes of that was hi speed freeway driving, is ridiculous. One day I will take a long drive and see how bad it gets. When I wheeled My Bronco, some trips were 12-14 hours of driving, and that tranny never went over 200*, and it worked 3x as hard as this little GP tranny.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Transmission overheating
    220+ is a bit high...
    Some of these transmissions run in the 180's all day long on abusive highway runs. If you have one of those.. you smile and enjoy it.
  10. #10 Re: Transmission overheating
    Jul 2010
    Coquitlam,BC,Canada
    If it stayed around 200, I'd be happy.
    i hate to even say this, but my tranny started to run hot, 225 on short trips, and then it let go on me. being it locked up, it got replaced.
    This is why I don't like the higher temps.
    Quote Originally Posted by 01Blackgtp View Post
    I would consider 220 normal for these in stock form.
    I agree, and that is so wrong for a transmission to go through this as "normal".
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Transmission overheating
  12. #12 Re: Transmission overheating
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    My stock trans with a cooler got to 240+ on several "normal driving" occasions. It let go at 80k...Granted 80k it was 11 years old. New trans with a...probably too big trans-cooler and oversized zzp radiator never gets above 195.
  13. #13 Re: Transmission overheating
    my new tranny on the stock cooler has yet to pass 170
  14. #14 Re: Transmission overheating
    Jul 2010
    Coquitlam,BC,Canada
    Keep it up. Maybe I'll get the a tranny cooler installed this year. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 2004 gtp comp g transmission overheating
    By daltman360 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2013, 11:26 PM
  2. **overheating**
    By tmackster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 04:18 PM
