Thread: 1999 gtp no overdrive
Results 1 to 20 of 21
  1. #1 1999 gtp no overdrive
    Aug 2016
    wi
    My sons car stopped shifting into od. Shifting from drive to 3rd gets no change in the rpm's. Do these trannys have a modulator? Any thoughts would be helpful. thanks.
  2. #2 Re: 1999 gtp no overdrive
    you need a new 4 th gear hub, its a 40 dollar part, but the tranny needs to have the side cover taken off and installed. not exactly a easy fix.
  3. #3 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    Thanks for the quick reply Scotty, I think I will take a look. Do I need to drain the fluids to take the cover off?
  4. #4 Re: 1999 gtp no overdrive
    dont think so, but you should do a pan drop and filter change, the splines wear off and they have to go somewhere right?
    im pretty sure theres a how to here done by billboost37, search his name with "easy" in the search, it will bring up all his how to threads.
  5. #5 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    Looked at Bill's how to's and I can do this. Also watched a video, a lot of work but it can be done. Where do I find this part and gaskets. orielly has the side cover gasket but no gear.
  6. #6 Re: 1999 gtp no overdrive
    ebay believe it or not lol its about 40 or less. just make sure its the upgraded hardened shaft.
  7. #7 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    Hey scotty, how the frick does a guy get the wiring harness loose from the top of the tranny?
  8. #8 Re: 1999 gtp no overdrive
    the fat oval one? pinch it from the left and right side pull it off. your mushing the the sides in. theres no other clips. squeeze and wiggle it off.
  9. #9 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    The power steering pump. can I just remove the bottom bolt from the sub frame? got to be 2 of them right?
  10. #10 Re: 1999 gtp no overdrive
    why the p/s pump? you pulling the engine out?
  11. #11 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    No Video I watched said to. I bet its the accumulator or something like that.
  12. #12 Re: 1999 gtp no overdrive
    pump shaft and pump maybe. ive not done this job myself. best to read bills how to closely, iirc theres pics and diagrams with the bolts marked to leave in and those to take out.
    as i under stand it you dont want to open the valve body leaving a few bolts in keeps it on one piece.
  13. #13 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    Just a quick update Scottydoggs, after a few choice words the cover is off. Thanks for the help. Gotta thank Bill too, used his how to.
  14. #14 Re: 1999 gtp no overdrive
    congrats my man. you got bigger balls then most. i cringe at the thought of going inside a transmission.
  15. #15 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    Got the culprit out. 3/4 of spline is missing. thanks again.
  16. #16 Re: 1999 gtp no overdrive
    now you gots an industrial paper weight.
  17. #17 Re: 1999 gtp no overdrive
    GTP Level Member
    Oct 2014
    Wow. That a good day! Wish I had the guts to try that if I needed.
  18. #18 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    1999 gtp no overdrive Attached Images
  19. #19 Re: 1999 gtp no overdrive
    well thats about worn to the nub there lol
  20. #20 Re: 1999 gtp no overdrive
    Aug 2016
    wi
    Update! Job completed. Gotta thank you guys for helping out. Would I do it again? Maybe.
  1. Overdrive at 38 MPH
    By Chadgervais in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2013, 05:58 AM
  2. No 3rd 4th or overdrive
    By Street stalker in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-20-2013, 07:49 PM
  3. overdrive
    By BOOSTED GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2011, 12:03 PM
  4. On-and-off overdrive...
    By Hogrydr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-22-2010, 11:32 PM
  5. No overdrive
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2009, 02:31 AM
