Thread: Transmission slipping from stop?? Read this
Results 1 to 4 of 4
  1. #1 Transmission slipping from stop?? Read this
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I found an article on the dreaded banging from a stop delayed engagement issue. I figured that since there are numerous posts about this I would post the link here.
    http://ls1tech.com/forums/ls4-perfor...ement-fix.html
    Here is the text from the article. None of this is mine, it is all borrowed and credited to Boattail455.
    "A little while back I posted that I noticed the transmission in my Buick slipping off the line. Being a mechanic I did some research and dug up several different causes for the scenario.
    The Super's transmission shifts very smooth from the factory, almost unnoticeable. From what I've read, to achieve a smooth shift the line pressure is reduced. Sometimes a waveplate just isn't enough to cushion the engagement of a clutchpack. Naturally I wanted to check the line pressure in my trans so I can continue onto pinpoint diagnosis. First I checked the line pressure with the Tech 2 at work.
    Minimum line pressure in P R N is 79-101 psi. The scan tool will show this value in amps. 1.0 amp is the spec for minimum line pressure in all gears. D4 D3 D2 line pressure is 74-86. D1 is 146-187. If you have the opportunity, you should take the Tech 2 with you on a test drive and try to duplicate the problem. I didn't have time so I just recorded D1 line pressure @ .78amp at 93*F. I really should have taken it out on a test run to watch the values through all the gears once the transmissionwas warmed up. But you'll see later on why I didn't need to.
    If you don't have a Tech 2 or access to one, there is a pressure test port on the case of the 4T65. On v6 cars its easily accessible. On v8 equipped cars, theexhaust pipe that crosses over the trans blocks it almost entirely. You could probably get the plug out, but there isn't enough clearance to thread a pressure gauge fitting in.
    I continued to dig and found several TSb's. The TSB that best fit my problem is bulletin no: 08-07-30-040B. The summary is that a new transmission pan magnet was released because the old magnet can become "saturated" with metal shavings. Once "saturated" it can no longer collect metal shavings and the shavings go to the PCS solenoid. The solenoid is magnetic and thus will collect the shavings, this throws off the readings and decreases line pressure. "When checking PCS line pressure and it shows that the line pressure is lower than required for a given current at the PCS or the transmission oil pan was removed, only then should thetransmission oil pan magnet be upgraded."
    My Super has 71K miles on it and I planned to do a transmission service anyway so this worked out. I called up the local Chevrolet dealer and ordered eight (8) quarts of Dexron VI and a filter. I talked to a service writer about my issue and asked if I did the work will GM still send me the new magnet free of charge. The dealer was more than helpful and ordered the magnet free of charge aswell. For reference here are the part numbers and price.
    Filter kit #24227477 $32.23
    Dexron VI #88861003 $6.47 (each)
    Magnet #29535617
    Start by dropping the pan, I removed all but a 2-3 bolts towards the front of the pan. It wasn't really messy but it will take a couple minutes to drain out of the pan. After dropping the pan I inspected it for burnt fluid, clutch material, how much metal is on the magnet, etc. The fluid was burnt and the magnet had an average amount of metal on it. After a quick trip to the parts washer I was ready for reassembly. For the 4T65 the TSB will have you keep the original magnet in it's "corner", behind the raised portion of the pan. The second magnet is installed on the new filter assembly. See photo for location. The gasket is reusable, just rinse and dry. Pan bolts torque is 13 ft lbs. Refill with Dexron VI, mine took just over seven quarts. I used GM Dexron VI. Its been over a month and 1,700 miles without any slipping.
    Just a heads up, the dealer won't perform this TSB under warranty unless you request a transmission service where the pan gets dropped. The TSB was very adamant about this. The magnet should only be replaced if the pan is being dropped under normal maintenance or diagnosis of a customer concern requires it.
    Hope this helps someone else out. I'm by no means an expert but stuff like this interests me alot."
  2. #2 Re: Transmission slipping from stop?? Read this
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I did all that, it still had the issue, the problem is once you notice the slip and bang the solenoid is also most likely saturated.
    it can also be this issue too http://www.tripleedgeperformance.com...ward-Cold.html
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #3 Re: Transmission slipping from stop?? Read this
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by Grimsin View Post
    Me too, it helped calm it down but didn't fix it.Its probably best to apply this fix for anyone not noticing this problem yet as a preventative measure. To those who get the trans rebuilt at a local shop make sure they apply the sonnax fix so it will not become an issue again. If you get a trans from one of the vendors it will have the fix already applied.
    This is worth a try as a last resort along with the trans tune cleaning, filter change, Lucas stop slip, transgo or DIY shift kit and line pressure adjustment.
    *Before adding the transtune cleaner put a strong magnet on the outside of the pan to collect any additional debris the clogged inside magnet may miss. run the trans tune cleaner for a week or two before pulling the pan for the attempted fix.
  4. #4 Re: Transmission slipping from stop?? Read this
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    Quote Originally Posted by rickisrad View Post
    For a diagram of the trans pan for exact magnet placement, see http://www.grandprixforums.net/threa...ighlight=4T65E. Page 5, reply #91
  1. transmission slipping
    By puffalot1977 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-14-2013, 02:31 PM
  2. Transmission slipping! Help!
    By TomDaBomb2u in forum General Grand Prix Discussion
    Last Post: 04-30-2012, 05:57 AM
  3. Transmission is slipping in drive
    By KarenC in forum General Tech Discussion
    Last Post: 06-01-2011, 03:22 PM
  4. transmission slipping or something else?
    By thegipper in forum Off Topic Discussion
    Last Post: 12-28-2010, 04:41 PM
  5. Transmission slipping?
    By WGPGT00 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2008, 07:27 AM
