Alright! I have my XP, ported heads, double roller, 2.8 IC, ported lower build in. The car pulls harder than the stock heads and 1.9 rockers build it had before I snapped the input shaft.
https://youtu.be/gsnhfXFXXRo
My issue is that I drove the car normal the day after first start with the tune it had in it before and everything was okay. I then decided to romp on it and the 2-3 shift at WOT has a shudder/slip. The kick down from 3rd to 1st and then when it was time for 2nd it was horrendous and I had to let off. It was an extreme shudder/slip. Since then even at part to moderate throttle it has a has a shudder from 1-2. Today I upped the 1st-3rd table 15 psi. It has firmed up the 1-2 shift at part/moderate accel. If you go anymore it will shudder and vibrate the steering wheel its that bad. 3rd gear going in at wot has not changed. I did install a new 30OM shaft, pcs, tcc, valve body gaskets and channel plate gaskets. Mind you this is a 170k trans I have no history on...
I highly doubt new 1-2 and 2-3 shift solenoids along with a cheep shift kit will fix this. What do others think?
