Thread: Grinding Transmission Noise in my 1999 GTP
Results 1 to 7 of 7
  1. #1 Grinding Transmission Noise in my 1999 GTP
    Jul 2016
    MO
    Picked up a '99 GTP from the city for $350. No key, 227xxx on the Odo.
    Got a key made today, charged the battery, and it starts!
    However, when I go to shift, there is the horrible grinding and rattling that you will hear in the video I'll post below.
    I have not tried to drive it yet.
    Carfax says the transmission fluid was changed August 2012 at 192xxx. It appears to still be full and clean.
    Sound is worst in reverse, then drive. Gets less scary moving down in the gears. Anyone heard these sounds before? Sound like a replace/rebuild? Something to try on my own or to let a shop do it? Any help is very appreciated.
    https://www.youtube.com/watch?v=rPv2KoSy4KU
    '99 GTP Coupe - She runs, but she's not perfect.
    '97 GT Coupe - Sold in New Orleans
  2. #2 Re: Grinding Transmission Noise in my 1999 GTP
    Jebus.
    That's one hell of the noise. Not sure the transmission pump would make that, it would have blown up by now for sure. I'd almost want to check the torque converter area, like the bolts and flex plate or something.
  3. #3 Re: Grinding Transmission Noise in my 1999 GTP
    St. Louis
    Does the car move/drive at all when you put it in gear?
  4. #4 Re: Grinding Transmission Noise in my 1999 GTP
    HUDSON
    Possibly broken flex plate, or torque converter, or internal transmission damage, the only way to tell is exploratory surgery.
  5. #5 Re: Grinding Transmission Noise in my 1999 GTP
    Yank either motor or trans.. Something needs attention for sure.
    Sounds a bit like a shot flex.
  6. #6 Re: Grinding Transmission Noise in my 1999 GTP
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Dumb question but... Does the speedometer show anything (move) when its in gear?
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  7. #7 Re: Grinding Transmission Noise in my 1999 GTP
    Jul 2016
    MO
    Okay, reply time:
    As I said, I had not tried to drive it. Today, I went in and let off the break, and no movement. I got just a little slip of reverse, but I call it a fluke. Park also does not work.
    The speedo did not move in drive while giving gas, but it did move about in reverse while giving gas. (No dumb questions.)
    Took the video to my mechanic, and he figured it was the flywheel. He said he'd tear into it, was confident he could get me moving without much money. So unless y'all think any of these options we discussed are easy enough for an amateur without a lift or engine hoist, I'll be dragging it up to him.
  1. Grinding noise when going 30 and up!
    By rbrown81 in forum General Tech Discussion
    Last Post: 11-06-2011, 08:43 PM
  2. Grinding Noise
    By EJOUIE in forum General Tech Discussion
    Last Post: 10-08-2011, 11:28 AM
  3. grinding noise
    By BoostnBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 11:28 AM
  4. grinding noise.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 01-03-2011, 11:03 AM
  5. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
