Thread: GMR 1" chain inspection
Results 1 to 6 of 6
  1. #1 GMR 1" chain inspection
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    Pulled my transmission out to give it a once over and replace the pump shaft with a proper modified one for the GMR input shaft.
    Very impressed with the 1" chain. After 2 years of beating on this thing with 600 or more HP on drag radials, many 10 second passes, and 1.4x 60' times, the chain is in the same condition as when it was originally installed.
    Unfortunately my diff didn't fare as well.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  2. #2 Re: GMR 1" chain inspection
    I break stuff selliott's Avatar
    Kansas City
    Good to know, hopefully I will be beating on one soon
  3. #3 Re: GMR 1" chain inspection
    hangover park IL
    our 1" managed to clip the case when we broke the IS, obviously it had to be a whiplash type deal but it does lend credence to the stator support deflection that daves noticed
    im glad as hell that yours and ours has the same finger deflection rofl
    ~James~ Psychotic Gearhead
  4. #4 Re: GMR 1" chain inspection
    Feb 2008
    Canada
    Killed four 7/8 chains in a year before I got this, and those would be touching the case when removed.
    Clutches and hard parts all looked good too. Stripped it down and put it all back together last night. Have to get some channel plate gaskets and fix the diff, then back in business.
  5. #5 Re: GMR 1" chain inspection
    Feb 2008
    Canada
    Forgot to mention, the key to my trans being alive after all the abuse I put it through is Dave at Triple Edge Performance. I run his valve body, channel plate and clutches. He has supplied parts quickly anytime I've had an issue, and his advice and support have been invaluable. He definitely knows the 4t65 and if you need one, buy from him. He is a huge asset to this community, so I try and support him, even buying stuff I can get locally from him instead.
  6. #6 Re: GMR 1" chain inspection
    Kansas City
    Good man!
  1. WTB 1" GMR Chain
    By PurpleGuy in forum Wanted To Buy - Parts
    Last Post: 12-02-2015, 01:23 PM
  2. Single 1" chain vs double 1/2" chain
    By Kyne in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 11:58 PM
  3. Omg 1" chain
    By MoarkatsINmuhtrailer in forum General Grand Prix Discussion
    Last Post: 07-22-2013, 08:17 PM
  4. L67 "Inspection" Advice
    By Quaraxkad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2013, 08:19 PM
