Thread: Question regarding broken apply band.
Results 1 to 3 of 3
  1. #1 Question regarding broken apply band.
    GXP Level Member
    Mar 2015
    Tomball
    So I notice a lot of guys that end up breaking the forward apply band so they have to hold it in 1st then it will shift after that. I know what causes it, but I haven't seen anyone say how long they were able to run with said broken band, nor have I have heard anyone say if they also had the failure to engage/ slamming preceding this issue. So my questions are:
    Before the band drive thingy broke did you have issues with taking off and it banging into gear? If so how long was is before you lost forward without downshifting?
    When you lost forward and had to downshift, how long were you able to do this before you were stuck like Chuck?
    Jeff
  2. #2 Re: Question regarding broken apply band.
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I am not sure as I have not run into this. I assume this means you are dealing with this issue? Going to dig into the trans yourself?
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  3. #3 Re: Question regarding broken apply band.
    GXP Level Member
    Mar 2015
    Tomball
    I have the occasional take off and bang into gear but it's not that bad. I'm just curious if people had that first before they actually broke the apply band tang driver thingy had the slip bang first, and how long someone has limped the trans around by shifting to first and then taking off.
    Jeff
  1. Forward Apply Band Replacement/Installation
    By sdavis11b in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2015, 06:00 PM
  2. Forward apply band
    By GTPgasm in forum General Grand Prix Discussion
    Last Post: 04-16-2014, 05:39 AM
  3. Gtp meth etc wide band question.
    By ctspoolintsi in forum PCM Tuning
    Last Post: 06-28-2012, 11:54 PM
  4. Forward band is broken
    By hector060864 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 12:44 PM
  5. Wide Band Question
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-16-2009, 06:50 PM
