Wouldn't you have to run the 3800 wiring harness? Or am I off base?
with the Bonnie having the computer inside the car it would probably be easiest to just swap it and re-pin the PCM connector to delete the extra wires that the North Star as and splice in a w-body engine harness
Or just put another north star in it teehee
nah id still go with a catera
german built rwd caddy thats the smaller cousin to the gto/commodore
then you could go auto or manual
id put the less ugly opel nose cladding on though....
James, the N* car has the pcm in the passenger compartment? All other 00+ Bonnie's had it under the hood in the airbox.
i dunno....most ive ever done is the skirt gaskets/wp/maint ****
never tried to find the pcm on the bonnie gxp....
I bet it's in the airbox.. all the others are.
Riv had the pcm inside.
Yeaaaah, your right.
The aurora has the spaceship tail lights. I get them confused.
I usually joke with him by saying "do you know the difference between an Alero and Intrigue?" hahahaha
Andrew from Bonneville Unlimited put a L67 into a bonneville GXP. He used 4t65eHD
