Thread: Maybe 4t60 problems with reverse
Results 1 to 4 of 4
  1. #1 Maybe 4t60 problems with reverse
    May 2008
    Sweden
    Hello
    I have a strange noise that appers every time i put reverse in.
    Its sounds like R R R and then engage. If I put it in drive it doesnt sound anything. But if i put in back to reverse then its sounds that again, and the sounds is just under a secend.. Hmm its hard to explain but rrrr and a minor clonk then its of to go and all that under a second and the sound isnt to loud but enogh to feel and hear it...
    Any Experience??
    Best regards
    Acke
    Drives today:
    GP SE 1989
    Citroen XM 1998
    "I love work so I always save some to tomorrow"
  2. #2 Re: Maybe 4t60 problems with reverse
    Oklahoma
    We have a nationally recognized 4T60/4T65E expert on these boards that goes by the screen name of Trannyman95 and hopefully he will see this and stop in and help you out.
  3. #3 Re: Maybe 4t60 problems with reverse
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Does the car have power in reverse like it is holding or do you have to wait until the noise goes away before it feels like a solid engagement? Many of the older transmissions had a problem with the style of lip seal on the reverse apply piston, which was a short type seal and would cause no reverse or slow engagement and was addressed by using a long style lip seal. If the trans is low on fluid you will hear a buzzing type noise when putting the trans in a gear that has higher line pressure such as reverse or manual 1.
  4. #4 Re: Maybe 4t60 problems with reverse
    May 2008
    Sweden
    Trannyman:
    Yess, the noise that accures has to go away before it engage in reverse.
    It dosent have any delays, I mean when you move the gear selector to reverse its supposed to take like under a second to feel the engagement..
    On my car it take under a second to engage but it make a more like a rattle noise or something.
    Now I got it how to make it explane the noise, its sound like if you have lifted up the car and putted in drive. The wheels start to move and WITHOUT putting your foot to the brake you bang the selector in to PARK.
    It makes a rattle/sawing noise!!! I havent done this ever one a car but I was riding in our citroen with my girlfriend behind the wheel and she wasent paying attention and did this... The citroen working like before (Thank god ) but I just wanted to explane the noise..
    When it engage it goes wheel without slippage or something.
    I did try to change the upper holderarms that holds the engine in position beacuse these were totally kaputt.. The noise is still there..
    Best regards
    Acke
    Drives today:
    GP SE 1989
    Citroen XM 1998
  1. 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 04-08-2015, 10:14 AM
  2. ICM Problems??
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2009, 12:53 AM
  3. 4T60-E (and HD) ID TAG deciphering info
    By Sinister Performance in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-31-2009, 08:42 PM
  4. HUD Problems
    By 03GTPFour in forum General Tech Discussion
    Last Post: 03-09-2008, 10:38 PM
  5. Gear Swap PICS now up in the 4T60/4T65E section!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-31-2007, 02:07 PM
