Thread: Can someone with an 04 post pictures of the fuel pump access hatch?
Results 1 to 16 of 16
  1. #1 Can someone with an 04 post pictures of the fuel pump access hatch?
    Oct 2011
    Toledo, OH
    I'm going to do a fuel pump rewire on my 2005 GTP and I likely do not have the access panel.
    So since I *may* want to do a fuel pump later, I'm not going to want to keep dropping the tank. So I'm going to cut out a hatch, but I need a real good idea how big I need and what kind of clearance I have.
    Thanks.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  2. #2 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    GXP Level Member
    Mar 2015
    Tomball
    When I was looking at 04's in the JY I noticed that the triangle area just behind the rear seat was the same size as the area on my 05' I keep meaning to buy an 04' access door and use it as a template. I am going this weekend so I will put that on my list of parts to pick up. I did see a picture somewhere here where someone had a picture of them pointing out the correct plumbing connections to the pump. There seemed to be about 2-3" to work with.
    Jeff
  3. #3 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    text me and i'll send you a pic matt
  4. #4 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Arizona
  5. #5 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Arizona
    Oh wait I forgot you have the v6 so our fuel pump modules might be diffrent. Honestly best way is to drop the tank and refrence a location
  6. #6 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by J57ltr View Post
    Jeff
    My floor pan has an indented oval that looks like it may be a template for the cut, but I need to be sure.
    Quote Originally Posted by 91parkave View Post
    Location should be the same though since the gas tanks are. Dropping the tank is a LOT of work just to find a location for something. Your pic at least give me a size idea.
    I've got a piece of diamond plate for my hatch
    7"
  7. #7 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Grab the cover from a 04 from the JY then you'll have a template and a cover then just sink some bolts or screws into it and bam... You"ll have the 04 hatch
    04 Comp G.
  8. #8 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Oct 2011
    Toledo, OH
    Wish it was that easy. Distinct lack of 04+ in my area.
    7"
  9. #9 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Just ask....
    I was literally staring a 04 with its fuel cover still there just the other day..
    04 Comp G.
  10. #10 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Oct 2011
    Toledo, OH
    Just ask....
    Thanks, but I just pulled up my carpeting and this is what I find. Looks like I couldn't even use a factory hatch now.
    Can someone with an 04 post pictures of the fuel pump access hatch? Attached Images
    7"
  11. #11 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Arizona
    My cover has magnets so it just comes on and off with no problem.
  12. #12 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Oct 2011
    Toledo, OH
    I can see now from your pic whoever cut that, cut the oval out first and that the oval is too far back. So I'll just cut a rectangle out starting at the beginning of the curve in the front and should be good.
    7"
  13. #13 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Arizona
    Yea the oval is to far but in my case it worked out cause I converted to a Vette external regulated setup the pump also makes a straight shot instead of the 2 90s that are about 5/16 in size at best
  14. #14 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    Stupid 04+ with no access who the fvcks great idea was this?
  15. #15 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    04 has the access panel tyler
  16. #16 Re: Can someone with an 04 post pictures of the fuel pump access hatch?
    GXP Level Member
    Mar 2015
    Tomball
    Meh, with an air body saw this is like a 15 minute job unless you screw it up royally.
    Jeff
  1. 04/05 fuel pump install- Fuel pump access in trunk
    By chrsmi1 in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2015, 09:26 PM
  2. Does a 1998 have a Fuel Pump Access Panel?
    By Burbman in forum General Tech Discussion
    Last Post: 08-21-2013, 06:27 AM
  3. 2004 grand prix fuel pump access door
    By gsi30 in forum General Tech Discussion
    Last Post: 10-24-2012, 08:25 PM
  4. 1994 Grand Prix Fuel Pump Access Door?
    By AMXTRA in forum General Tech Discussion
    Last Post: 09-23-2012, 09:27 AM
  5. Please tell me this is NOT the access door to the fuel pump!!
    By spider4 in forum General Tech Discussion
    Last Post: 01-05-2012, 02:32 PM
