Thread: Best drill and slotted rotor.
Results 1 to 20 of 38
  1. #1 Best drill and slotted rotor.
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    I have a 2004 GP GT2 where would be the best place to order drill and slotted rotor all around for my car
  2. #2 Re: Best drill and slotted rotor.
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    I got a set off of eBay for my 98. They work fine. Stop fine. No warping. I know a lot of people look down on them because they are made in China, but, most off the shelf OEM type rotors are made in the same factories with the same materials/machines. I see nothing wrong with them.
    Official GPF Red Neck
  3. #3 Re: Best drill and slotted rotor.
    Chesterton, IN
    Quote Originally Posted by MGRead View Post
    You can get powerstop drilled and.slotted rotors front and rear with ceramic pads on rockauto.com.... think I paid like 225 for the.whole kit. Dont look under rotors or brake pads look for pad and rotor kits... search Google and you can prob find a 5% off code to...
  4. #4 Re: Best drill and slotted rotor.
    gardner,mass
    Quote Originally Posted by TwiztdWun View Post
    The problem with those are they are actually drilled. They have a tendency to crack.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  5. #5 Re: Best drill and slotted rotor.
    Banned
    CT
    The best drilled rotors are the ones that aren't drilled.
    I'm sure you're aware that the holes are negative for performance.
  6. #6 Re: Best drill and slotted rotor.
    gardner,mass
    Exactly if anything just get some high quallity slotted. But rockauto does have some drilled/slotted for real cheap.
  7. #7 Re: Best drill and slotted rotor.
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by SnowFlake View Post
    I have to completely disagree... If they were soo bad for performance then they wouldnt come stock on the REALLY high dollar cars. The key is to find ones that have been cast with the holes in them and not cast then drilled.
    I run R1 Concepts and I love them. I have put about 40-50k on them and have ZERO cracking and I use my brakes hard sometimes.
    2011 F-150 Yote powered
  8. #8 Re: Best drill and slotted rotor.
    Banned
    CT
    Quote Originally Posted by Iceman6669 View Post
    You don't have to agree with me, you can just be wrong.
    It's purely for aesthetics.
  9. #9 Re: Best drill and slotted rotor.
    Jun 2011
    This is just a good cross section. Maybe there is more to the drilled thing then you thought?
  10. #10 Re: Best drill and slotted rotor.
    gardner,mass
    Technically its for heat dispersion and causes the rotor to warp less under extreme conditions and keep the pads from glazing but as far as stopping you faster it does the opposite because the pad has less surface to grip.
  11. #11 Re: Best drill and slotted rotor.
    Jun 2011
    Less surface is offset by the fact that you get less brake fade and better heat dispersion.
  12. #12 Re: Best drill and slotted rotor.
    gardner,mass
    Also depending on if you run semi metallics or ceramics. Semi metallics are better stopping power for the average person but under severe conditions will glaze and lose stopping power and thats where ceramics come in. Ceramics are alot harder of a pad and dont really melt down under heat but put alot more heat into the rotor causing warping so the drilled(machined) rotors are a better option. But as far as stopping the fastest if your not counting heat semi metallics with your standard rotors are the best.
  13. #13 Re: Best drill and slotted rotor.
    Jun 2011
    I run Carbon metallic pads with the R1 concepts drilled and slotted rotors. And once they are warm it is a MUCH better stop then stock.
  14. #14 Re: Best drill and slotted rotor.
    gardner,mass
    Yea thats because the pad meterial will seat into the rotor and basicly cause it to be pad on pad. What i do is get up to like 80 and stand on my brakes to a direct stop. Do this like 4 times and it causes the rotor to get so hot that it will melt the pad embedding it into the rotor so instead of pad on metal its more pad on pad if that makes sense.
  15. #15 Re: Best drill and slotted rotor.
    Apr 2012
    Goderich, Ontario
    -Paul Walker
  16. #16 Re: Best drill and slotted rotor.
    Banned
    CT
    Lol no.
    Who told you this?
  17. #17 Re: Best drill and slotted rotor.
    Jun 2011
    That my friend is common sense. While there is less contact area there is in fact MORE surface area and THAT helps with heat distribution.
  18. #18 Re: Best drill and slotted rotor.
    Banned
    CT
    You're forgetting that all of those holes are taking away material from the rotor, which is a heat sink.
    Less material means the rotor loses heat sink capacity.
    The holes do not provide any cooling advantages, they're actually a cooling disadvantage.
    All of the rotors you posted are cast that way for aesthetics.
    If you want to see what actual race cars use...
    F1... solid disk.
    Nascar, slotted.
    The slots actually help with glazing, gas dispersion, and keeping the pad clean.
    It does not give a cooling benefit at all.
    Not to mention the rotors regular guys put on their civics and grand prix's are actually DRILLED and can fail catastrophically.
  19. #19 Re: Best drill and slotted rotor.
    Jun 2011
    The holes in the rotor will act as a heat sink too. The more surface area you have the more cooling effect it has do to more contact with the cooler air. Same principle any heat sink works off. I will concede that it does take away from contact surface, that effect is offset by the cooler temps and less fade.
  20. #20 Re: Best drill and slotted rotor.
    Banned
    CT
    You're actually just wrong and you can't be reasoned with so I'm done trying to educate you.
  1. Slotted or not
    By DJNight2k in forum Brakes/Suspension/Chassis
    Last Post: 07-31-2013, 06:12 PM
  2. Use Drill to Wax a Car?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-08-2013, 08:25 PM
  3. ~ " Drill or not to Drill? " ~
    By ActionJackson1985 in forum General Tech Discussion
    Last Post: 12-07-2009, 12:54 PM
  4. An afternoon with the drill and some polishing compound.
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 04-26-2008, 05:32 PM
  5. Drilled/Slotted or both?
    By GP2003GT in forum Brakes/Suspension/Chassis
    Last Post: 04-20-2008, 12:43 PM
