Thread: Best drill and slotted rotor.
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: Best drill and slotted rotor.
    The Boss Iceman6669's Avatar
    Jun 2011
    You're right. All these people in EVERY CAR that runs drilled rotors are completely retarded.
    But I will just leave this here for you
    " a heat sink is a passive heat exchanger that cools a device by dissipating heat into the surrounding medium"
    "A heat sink is designed to maximize its surface area in contact with the cooling medium surrounding it, such as the air."
    2011 F-150 Yote powered
  2. #22 Re: Best drill and slotted rotor.
    gardner,mass
    All this being said we do not drive race cars as much as we want to believe. You nor i are going to notice anything running drilled or not and the only true benifial rotor would be to get slotted for the help with glazing and keeping the pad clean.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #23 Re: Best drill and slotted rotor.
    Jun 2011
    I personally noticed a HUGE improvement when I did my pads and rotors. BUT I will admit that might have been the Pads.
  4. #24 Re: Best drill and slotted rotor.
    Jun 2011
    This is what R1 concepts say about their rotors... Granted it is the vender trying to sell a product but I would assume they have some kinda proof to their temp drop claims.
    R1Concept's Cross-Drilled rotors helps prevent warping of the rotor by releasing heat and cooling the rotor by up to an additional 105 degrees Fahrenheit when compared to non-drilled rotors. In addition, all cross-drilled rotors are chamfered, meaning there is a slight slant at the opening of the hole. Our chamfering process reduces the chances of rotor cracks without compromising performance.
  5. #25 Re: Best drill and slotted rotor.
    gardner,mass
    I noticed a huge improvement when going from ceramics to semi metallics(again i dont drive a racecar). Im kind of interested in your carbon metallics, I havnt looked into these.
  6. #26 Re: Best drill and slotted rotor.
    Jun 2011
    http://www.performancefriction.com/a...rake-pads.aspx
    Thats what Ive got. Maybe there is a little info on there for you. I honestly only got them because they came with the rotors when I bought them new off a local. But I dont think I will ever go back.
    http://www.amazon.com/Performance-Fr...iction+0699.20
  7. #27 Re: Best drill and slotted rotor.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    You guys notice them dust more less compared to a Ceramic pad? I don't know much about pad material and such and was curious, im currently running some Monroe Ceramic pads and they dont dust at all but my brakes are really ****ty for stopping power. I was curious. I planned on getting a powerstop front and rear kit for my next brake service but if these pads are that good, I'll just get the rotors and these pads.
    Im done thread jacking now but im sure this info helps OP
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  8. #28 Re: Best drill and slotted rotor.
    gardner,mass
    Yea i did run the monroe ceramics untill they somehow warped the hardware and caused them hit the rotor at an angle thus causing extremely bad squeeling. Not to mention braking was ****. I switched to wagner semis and they seem to be doing great.
  9. #29 Re: Best drill and slotted rotor.
    Apr 2012
    Dayton, OH
    Mine are scary ****ty right now, I can probably almost put the pedal to the floor before the wheels lockup and it feels just like they arnt stopping me lol. I need to re bleed them also I think I have some air in them.
    2012 F150 STX
  10. #30 Re: Best drill and slotted rotor.
    Jun 2011
    I've literally got like 40k+ on my current setup and my pads look and feel like they could go another 100k lol.
  11. #31 Re: Best drill and slotted rotor.
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I have the power stop drilled and slotted rotors with ceramic pads from summitracing(same as rock auto)
    had them for 4-6 months now and they are great, stopping power is awesome but its probably the ceramic pads. 3 year warranty on them also.
    this is what you get.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  12. #32 Re: Best drill and slotted rotor.
    Aug 2013
    McDonald PA
    ^ this is what I bought not installed yey
  13. #33 Re: Best drill and slotted rotor.
    Enfield, CT
    Quote Originally Posted by Ginseng View Post
    Also depending on if you run semi metallics or ceramics. Semi metallics are better stopping power for the average person but under severe conditions will glaze and lose stopping power and thats where ceramics come in. Ceramics are alot harder of a pad and dont really melt down under heat but put alot more heat into the rotor causing warping so the drilled(machined) rotors are a better option. But as far as stopping the fastest if your not counting heat semi metallics with your standard rotors are the best.
    idk what semi-metallics you running or talking about but thats not true. Higher quality semi-metallics like NAPA/Raybestos don't glaze and lose stopping power. They are also a pretty hard pad. Most ceramics are on the softer side even wagner thermoquiets are softer than NAPA/Raybestos semi metallics. I agree with carbon metallics being a great pad and the same goes for ferro carbon
  14. #34 Re: Best drill and slotted rotor.
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Ive had those exact same powerstop rotors and pads for a couple years on both my gp's.I give them a workout alot,lol.There holding up really well.They do make a little noise when you stop hard tho.You can tell the pads are going over holes, barely noticeable,not an issue.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  15. #35 Re: Best drill and slotted rotor.
    Arizona
    As others have mentioned I have never warped a cross drilled rotor. Blanks yup. So for the naysayers of cross drilled on a daily driver/auto x/ track car I'll take drilled.
  16. #36 Re: Best drill and slotted rotor.
    I picked up a set of R1 F body drilled/slotted when I put my car together. Not positive, I believe I paired them up with a set of scorched (no break in) ceramic pads also from R1. The combo was amazing. The car would stop great, low dust, never a fade or issue pulling bone head stops from fast speeds. There were very small spider cracks around the holes, nothing that affected them at all. The rotors did not have a groove in them from the pad wear. If not for the cracks, I would have run them another 60K with another set of pads. That's right.. 60K miles on a set of pads.
    Liked them so much I went with R1 again and this time decided slotted only.
  17. #37 Re: Best drill and slotted rotor.
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    Thank I know it not a racer car but I love to stop light run. Me and my wife are hard on brakes. I will and have warped rotors in weeks after install. That is why I use drill and slotted
    Sent from my iPad using Tapatalk
  18. #38 Re: Best drill and slotted rotor.
    If you are having that issue, I totally understand where you are coming from. I had a 97 Bonneville and upgrades aren't easy, so I warped them constantly and replaced often. Once I went W body, I put the F body calipers on. That gives you a larger rotor and two piston caliper. They work so much better IMO and combined with that drilled/slotted rotor I was mentioning, totally amazing.
    Ask some of the guys on here that have visited, I put them in the car and make them abuse it.. It's all good
  1. Slotted or not
    By DJNight2k in forum Brakes/Suspension/Chassis
    Last Post: 07-31-2013, 06:12 PM
  2. Use Drill to Wax a Car?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-08-2013, 08:25 PM
  3. ~ " Drill or not to Drill? " ~
    By ActionJackson1985 in forum General Tech Discussion
    Last Post: 12-07-2009, 12:54 PM
  4. An afternoon with the drill and some polishing compound.
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 04-26-2008, 05:32 PM
  5. Drilled/Slotted or both?
    By GP2003GT in forum Brakes/Suspension/Chassis
    Last Post: 04-20-2008, 12:43 PM
