Thread: E85 on 2005 gtp
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    Who's done it?
    Did youbhave to drop the tank?
    What exact fuel pump and rewire kit did you use? I know I need 60lb inj
    Any other info will help.... thanks
    Sent from my SGH-T999N using Tapatalk
  2. #2 Re: E85 on 2005 gtp
    You'll probably have to drop the tank to get to the fp. Check your trunk first for the access panel though.
  3. #3 Re: E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    Yea I know I will is anyone running e85 on the forums here on a 04+
  4. #4 Re: E85 on 2005 gtp
    You'll need info for 05+ I'm thinking 04 was still like the old style minus the returnless system. I ran a casper rewire on my comp g.
  5. #5 Re: E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    Yea I hear that's good for me but prolly have to run it under the car or drill a hole
  6. #6 Re: E85 on 2005 gtp
    I ran mine under the car
  7. #7 Re: E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    What pump you running
  8. #8 Re: E85 on 2005 gtp
    stock right now. I'm on pump gas though.
  9. #9 Re: E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    Ahhh ok you going to go e 85
  10. #10 Re: E85 on 2005 gtp
    no there aren't any stations close to me. I'm not going to drive 30 min away just to get gas.
  11. #11 Re: E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    That sux there's one a couple miles from me
  12. #12 Re: E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    What's the difference between a Casper and the prj
  13. #13 Re: E85 on 2005 gtp
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Before you go to E85 do your research. E85 will deteriorate any plastic or rubber it comes into contact with. The fuel sloshing around in your tank will cause friction. This friction in turn will draw moisture. The moisture will eventually cause rust in your engine. The moisture by friction is the reason it can't be transported by pipeline. I worked 31 yrs in the petroleum industry. E85 is an environmental con to hit the oil producers. I wouldn't put E85 in a lawnmower. But you boys do what you want it your car.
  14. #14 Re: E85 on 2005 gtp
    You my friend have read far to many "horror stories" about e85.
    99% of the people that use E85 are after if for the the performance aspect of it and could careless about mileage.
  15. #15 Re: E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    Performance I want lets hope indont get rust lol
  16. #16 Re: E85 on 2005 gtp
    Sep 2013
    tulsa okla
    Well like I said these are your cars do what you want, but you will get rust and E85 will break down any rubber gaskets ,seals and o rings it comes in contact with. And it will cause rust.At 61 yrs old I was in this business long before the Eco fuels came along.
  17. #17 Re: E85 on 2005 gtp
    Many people have run e85 for years with no ill effects.
  18. #18 Re: E85 on 2005 gtp
    Jun 2013
    Hollywood ,FL
    Ds u got ur intercooler in yet
  19. #19 Re: E85 on 2005 gtp
    Quote Originally Posted by kurupt305 View Post
    pretty sure your tank is plastic, so point is moot.
  20. #20 Re: E85 on 2005 gtp
    No I'll pRobably do it next oil change
  1. 2005 gtp
    By steveski in forum Introductions/Noob Questions
    Last Post: 03-07-2013, 02:05 PM
  2. HUD for 2005 GP
    By Shoggy24 in forum General Tech Discussion
    Last Post: 02-28-2010, 12:37 PM
  3. Looking at a 2005 GP GXP
    By Raz97GT in forum General Tech Discussion
    Last Post: 05-09-2009, 09:16 PM
