Thread: Aftermarket headlight difference
Results 1 to 3 of 3
  1. #1 Aftermarket headlight difference
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    When I bought my GXP last fall the headlights were in rough shape. I wetsanded, polished, etc and they looked better (not perfect) and quickly were weathered again. I plan on replacing them and have been reading up on doing a retrofit. I was looking at Rockauto and noticed they have 3 different levels of the TYC replacement headlights. "Regular Inventory", "NSF Certified", and "CAPA Certified". What's the difference. Is it like airplane parts where the part is the same and you are paying for the stamp on it or are there actual quality differences? I know members here have had many headlight assemblies apart and was hoping someone had dealt with these and could clarify.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  2. #2 Re: Aftermarket headlight difference
    Pennsylvania, USA
    From what I remember reading on here, all the aftermarket headlamps are made by the same company and distributed and sold under several brands. Normally I'd expect the certification to denote some guarantee of quality.
    NSF certification is more a health and safety certification (not using materials that are hazardous or let off fumes in high temps, etc.), where as CAPA certification has to do with meeting OEM quality. The "non-certified" ones.are still DOT compliant and should work just fine, especially since you're retrofitting the low beam portion anyways.
    If you had all three in hand, I bet you'd have trouble telling any difference if there even is one. I'd personally buy the cheaper ones and use the extra cash towards the projectors, lights, and ballasts. The only problems you may or may not run into with aftermarket headlamps are the seals letting condensation in (which are redone by you while retro'ing, so no worries), and maybe getting a haze in a few years. But even OEM's do that :P A nice polish and a reapplication of some UV compound will make them new again.
    That's my 2ยข, but I bet other people have some input too.
  3. #3 Re: Aftermarket headlight difference
    I've used several set of headlights from vision..all appear close to oem and output is close to the same. The only difference I've noticed is the stamping on the lens (aftermarket seems to have more vs oem) which shouldn't make a difference since unless your looking for it you won't notice.
    04 Comp G.
  1. Difference in NA s1x and SC s1x cam
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2012, 07:49 PM
  2. difference between fog switchback and headlight switchback side markers?
    By des19 in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2012, 11:11 PM
  3. Two Morimoto projectors one cup...uh...I mean headlight...headlight
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 03-23-2011, 05:07 PM
  4. Is there a difference between 05 and 06 GXP
    By baw1099 in forum Off Topic Discussion
    Last Post: 06-29-2008, 10:17 PM
