Thread: Squeaky Steering Wheel
Results 1 to 8 of 8
  1. #1 Squeaky Steering Wheel
    SE Level Member biggd1980's Avatar
    Feb 2013
    Iowa
    I purchased an 04 Grand Prix GT2 around March. Once it started to warm up outside I noticed my steering wheel squeaking on low speed turns. After searching several forums I thought that I should lube my ISS. Before I made it that far I had to take her in because of clunking over bumps being felt up into the steering wheel and they changed the ISS. From what I understand there was a service announcement to update the ISS and the new model that was just installed does not require being greased. So my question is, why is my steering wheel still squeaking??
  2. #2 Re: Squeaky Steering Wheel
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Perhaps your steering wheel shroud isn't aligned properly, causing it to rub on the back of the steering wheel.?
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Squeaky Steering Wheel
    SE Level Member crysalis's Avatar
    Mentor, OH
    I had the same problem on my 06 GT. I had a warranty and they ended up changing the "spring" and not the shaft. I would have to look back at the receipts to see what they actually did, but that is what the tech told me. I never bothered to figure out what it was since I had just bought the car. Took it in and a few hours later, no more squeek.
    2006 GP GT S/C | CAI | Overkill PCM | PLOG | 3" Catted DP | ZZP Strut Brace -- SOLD the car in treason for a Hemi Charger >:]
  4. #4 Re: Squeaky Steering Wheel
    only spring would be the clock spring, its for the airbag and radio controls on the wheels. i could see it making some noise. not hard to change either.
  5. #5 Re: Squeaky Steering Wheel
    Feb 2013
    Iowa
    I appreciate the suggestions everyone. When I asked the guy at the shop he said that he is not sure why it squeaks, his car does that too and not sure how to make it stop. Great help huh? Any idea where the clockspring is located? Reason I ask is because for one the cost of the part, and secondly where the squeak seems to be coming from is behind the steering wheel where it attaches to the steering column.
  6. #6 Re: Squeaky Steering Wheel
    take the airbag off, then the wheel, its looking right at you. theres a ring clip holding it on the column shaft. so its right under the wheel.
  7. #7 Re: Squeaky Steering Wheel
    Feb 2013
    Iowa
    Any idea if it is repairable instead of replacing it? The cheapest replacement I found online was about $150.
  8. #8 Re: Squeaky Steering Wheel
    you may be able to take it off and spray lock graphite spray in to it.
  1. Squeaky noise from front passenger wheel...
    By 06GXPGAL in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2013, 09:48 PM
  2. Steering wheel
    By Bones007 in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2012, 08:21 PM
  3. I'd like a new steering wheel
    By gunsn88 in forum General Tech Discussion
    Last Post: 09-13-2011, 11:14 AM
  4. steering wheel help
    By ham4864 in forum General Tech Discussion
    Last Post: 11-27-2010, 07:32 AM
  5. Steering Wheel
    By RideMr2 in forum General Tech Discussion
    Last Post: 05-27-2010, 11:41 PM
