Thread: DRL ideal
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: DRL ideal
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    OK, I had some time to dig into this more yesterday. My goal is to be able to gain more control over my lights, but not nec cut out DRL all together.
    One obvious answer is the use the signal for the dash lights (can grab this easily). The only potential problem is that this drops below 12v if you use the dimmer. I have never used the dimmer knob other than to see that it worked and when testing yesterday so this wouldn't be that big of a deal.
    I did some searching and found that the sensor on the dash gives a ground signal rather than 12v. The wire to the BCM is light green with a black stripe and is in position 15. When using it as a ground and connecting it to my multi meter, I get full 12v (actually higher) when it gets dark and the headlights come on automatically. This ranges and changes as the sensor sees light. I saw as low as 6v yesterday, but it wasn't very bright. I imagine I could get close to 0 on a sunny day. I tried a test using this for the ground on a relay and the relay would not switch. This was a standard 50amp relay I had laying around. I am trying to figure out how get a relay that will switch (close) as the ground allows a full 12v, but open back up as this drops down to 10-11 volts. That sort of electrical thing is not something I am used to dealing with. Any insight would be appreciated. As I continue to work on this, I will post my findings.
    I tested my voltage for pulsation at the headlights when DRL's were active and saw a constant full voltage no matter what test light, multimeter, etc that I used. I expected to see pulsation as many have experienced, but could not duplicate it.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  2. #22 Re: DRL ideal
    Arizona
    Quote Originally Posted by LeadfootCJ7 View Post
    At this point what are you trying to accomplish? IF you tape over your light sensor youll have no DRL. And you just switch your headlights on manually.
  3. #23 Re: DRL ideal
    I live here. DirtDog's Avatar
    Jun 2012
    Or, quad retro fit headlights with manual on and off switch like i started. the headlights are almost done (classypontiac is making them) i already got my switches installed and the wiring ran. For my headlights i no longer use the stock headlight switch that is built into the car. I bypassed it completely. Here is my setup
    Its a Quad Retro
    3 switches
    1) for just the normal low beams (only one light for each headlight is on)
    2) for quad low beams
    3) for quad high beams (and only dual high beams if you leave switch #2 off.
    the above added with my projector fog lights = recidulous amount of light but completely fixes the DRL problem in a very nice way if you ask me. but that's just my .02
  4. #24 Re: DRL ideal
    Mar 2012
    NC
    Quote Originally Posted by DirtDog View Post
    Its a Quad Retro
    3 switches
    How do you live in Jacksonville yet I have not seen your car? LOL
  5. #25 Re: DRL ideal
    Jun 2012
    Well I've been in jacksonville for coming up on two years. but i live on base. You military? BTW I'm deployed right now so my cars in storage with that semper fi storage place. not a bad deal really
  6. #26 Re: DRL ideal
    Mar 2012
    NC
    Ahhh...I've been here since August. Not military...moved here to teach high school. Thanks for all that you do BTW!
  7. #27 Re: DRL ideal
    Jun 2012
    well sh*t man, when i get back in we can meet up. i got a few other GXP guys locally i know and meet up with every now and then.
  8. #28 Re: DRL ideal
    Mar 2012
    NC
    I'm outta here in June...gonna be back before then?
  9. #29 Re: DRL ideal
    Arizona
    im jealous, Its just me representing grand prix down here in AZ, nobody else apparently gives a **** lol
  10. #30 Re: DRL ideal
    Jun 2012
    sven no i won't be back until late in the year. just left at the end of january
  11. #31 Re: DRL ideal
    Mar 2012
    NC
    Quote Originally Posted by 91parkave View Post
    I don't even own a GP anymore but I still like the scene.
  12. #32 Re: DRL ideal
    Jun 2012
    and 91parkave, i guess you're just holdin down the fort in your neck of the woods for GPs then
  13. #33 Re: DRL ideal
    Mar 2012
    NC
    Well, that sucks. Stay safe over there bud. Again, thanks for what you're doing.
  14. #34 Re: DRL ideal
    Jun 2012
    ahhh okay, well you'd still be welcome to chill with the group sometime. where you heading to next?
  15. #35 Re: DRL ideal
    Mar 2012
    NC
    Headed back home to PA. NC has pretty much ruined any semblance of life I had going, so it's time to go.
  16. #36 Re: DRL ideal
    Jun 2012
    well, this part of NC will ruin NC for ya. it's a poopie hole.
  17. #37 Re: DRL ideal
    Mar 2012
    NC
    Nah, I got screwed before I even moved here. State changed legislation regarding my pay effective Aug 1...I started Aug 20.
  18. #38 Re: DRL ideal
    Oct 2012
    Houston, TX
    I have gone back and forth, but currently I am settled on this: I want the fog lights and LEDs (or LED Halos) on. I am doing a HID projector retro soon and don't want them on all the time. Then, when it is truly dark have the projectors come on with the fog lights etc. The side benefit is the fog lights being on with the headlights, etc without always having to switch them on.
  19. #39 Re: DRL ideal
    Arizona
    Then you have a lot of relays To wire up and figure out. I have retros ready but I just have my sensor taped over and using a harness
  20. #40 Re: DRL ideal
    Oct 2012
    Houston, TX
    No doubt. I used to install stereo's and alarms so relays don't scare me. I am leaning towards using the dash light signal to trigger this. Once the ambient light sensor shows dark it takes 10-15 seconds before the headlights are turned on. This would likely be better because driving under a bridge during daylight might trigger the retro headlights on for a second and then right back off which isn't good for them. I will likely install an override switch in the event I want to dim the interior lights and need the headlights on. It will just take a bit of time and wiring.
  1. would it be a bad ideal to change the supercharger oil at 128,000 miles
    By pontiacmanj2 in forum Off Topic Discussion
    Last Post: 05-09-2012, 11:42 AM
  2. Ideal values readout
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-07-2010, 01:19 PM
  3. Ideal timing
    By 01gpgt01 in forum General Tech Discussion
    Last Post: 09-26-2010, 03:30 PM
  4. Need advice for an ideal system...
    By Vespers47 in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2009, 04:14 PM
  5. Ideal exhaust cutout loc.?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-03-2008, 02:40 PM
