Thread: 2004 GTP Comp G Exhaust Smells bad
Results 1 to 20 of 22
  1. #1 2004 GTP Comp G Exhaust Smells bad
    Mar 2013
    Burton,MI
    Today i noticed that my exhaust smells bad like rotten eggs. What looking what in can do to fix it. Looked online and it say a multiple of things, Conveter, o2 sensor, maf sensor, etc... Was hoping if anyone knows this issue and knows how to fix..
    PS.... this is supercharged so i run premium gas in it all the time
  2. #2 Re: 2004 GTP Comp G Exhaust Smells bad
    GTP Level Member joshv's Avatar
    canada
    has there been a new cat installed ?? mine did for a wile right after puting a new cat in
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  3. #3 Re: 2004 GTP Comp G Exhaust Smells bad
    Your cat is probably bad.
  4. #4 Re: 2004 GTP Comp G Exhaust Smells bad
    Portland Oregon
    Definitely the "conveter"
  5. #5 Re: 2004 GTP Comp G Exhaust Smells bad
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    catalytic converter
    COMP G
  6. #6 Re: 2004 GTP Comp G Exhaust Smells bad
    Mar 2013
    Burton,MI
    Ok. So i went on ZZP and they have a converter like this... ZZPerformance - Catalytic Converters #ZZ-CATC
    Would this have to be welded on or just use a bracket to hold it on?
  7. #7 Re: 2004 GTP Comp G Exhaust Smells bad
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Your cat's got an hairball, replace it. Yes you need to get its tail and head welded. Make sure to skin both ends nicely.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  8. #8 Re: 2004 GTP Comp G Exhaust Smells bad
    SE Level Member sdogg201's Avatar
    Mar 2012
    Saginaw
    Yep its the cat
  9. #9 Re: 2004 GTP Comp G Exhaust Smells bad
    You could just buy a catted dp from zzp. It take like 30 min to swap it.
  10. #10 Re: 2004 GTP Comp G Exhaust Smells bad
    Mar 2013
    Burton,MI
    ok. so does not replacing it hurt the car? I wont be able to get it for about a month. Ill get the direct fit one though
  11. #11 Re: 2004 GTP Comp G Exhaust Smells bad
    Mar 2013
    Burton,MI
    Ok so found a downpipe off road 2.5 with o2 bung. Is this too loud to run on streets and does the o2 sensor simply plug into the bung with no error codes?
  12. #12 Re: 2004 GTP Comp G Exhaust Smells bad
    You might need an o2 ext depending on the dp. You'll get a p0420 code running catless.
  13. #13 Re: 2004 GTP Comp G Exhaust Smells bad
    Mar 2013
    Burton,MI
    So i would have to flash the pcm?
  14. #14 Re: 2004 GTP Comp G Exhaust Smells bad
    gardner,mass
    Quote Originally Posted by daltman360 View Post
    No.. Go to the parts store and find a 2 pack of spark plug non foulers(they are like $5). You need to drill a hole in one(believe its a 1/2 in drill bit) and leave the other as is. Screw your o2 sensor into the one you drilled a hole through, then screw that one into the untouched one. Put that into the o2 bung and you should be good. Basicly it limits the ammount of exhaust that can hit the o2 sensor simulating you actually having one.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  15. #15 Re: 2004 GTP Comp G Exhaust Smells bad
    Mar 2013
    Burton,MI
    Do you know if they make a 2004 grand prix O2 Emulator just to make things easier?lol
  16. #16 Re: 2004 GTP Comp G Exhaust Smells bad
    gardner,mass
    Its not hard.... Takes 10 minutes
  17. #17 Re: 2004 GTP Comp G Exhaust Smells bad
    Mar 2013
    Burton,MI
    Just going to wait until next month and get the 3' zzp down pipe and 3" exhaust. Would i see any HP increase?
  18. #18 Re: 2004 GTP Comp G Exhaust Smells bad
    Don't get the exhaust just get the dp
  19. #19 Re: 2004 GTP Comp G Exhaust Smells bad
    Mar 2013
    Burton,MI
    Will the 3" down pipe still work when everything else is still stock?
  20. #20 Re: 2004 GTP Comp G Exhaust Smells bad
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    $5 o2 cheater/non fouler how-to - evolutionm.net
    ^ i know its not our cars but its the same thing. Takes 10 min and only $5, well worth it.
  1. 2004 Comp G
    By 04BlackComp_G in forum For Sale - Vehicles
    Last Post: 02-04-2012, 11:17 PM
  2. 2004 comp g
    By nickbato in forum Introductions/Noob Questions
    Last Post: 03-20-2011, 10:24 PM
  3. my new 2004 Comp G!
    By colindunn in forum Off Topic Discussion
    Last Post: 10-31-2010, 08:57 PM
  4. Help!! 2004 Comp G Smells
    By dnnschuett in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 09:16 PM
