Thread: 04+ Intake shots
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 04+ Intake shots
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I'm sure there's a ton of these threads but I'm trying to get an intake pieced together at the local hardware store. I'd like to see what the 04+ guys setup looks like. Seems everyone has a different variation just want to pick and chose the best looking setup.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: 04+ Intake shots
    Feb 2013
    Detroit, MI
    $45 9" k&n cone with 4" opening. 2 couplers from home depot.. $3.50-4. 1 45* pvc. 3" with wider opening where it bows out to fit the 4" opening. $4.
    Or autozone has the chrome angle tubes for $12 but there only 3" opening I believe. Ab d they have black, blue, or red couplers for $7-8
  3. #3 Re: 04+ Intake shots
    Feb 2013
    Detroit, MI
    I brought my filter into home depot to make sure itd fit into the cone too by the way. I bought the wrong size pvc just by guessing. The tb is around 3-3.25" and the maf is 3.25" I think I read.I drilled a hole in the coupler and put the vaccum or pcv valve w.e it is n put it between the tb n maf..you can see in the first pic
  4. #4 Re: 04+ Intake shots
    3" to 3.5" coupler; 3.5" Bpi velocity stack; R2c Filter
  5. #5 Re: 04+ Intake shots
    Oct 2011
    MI
    I think I'm going to hack and cut my inner fender for a Fwi. Seems like my intake now sees quite the temp jump when viewing on Torque from my phone.
    It's just a ghetto stock size k&n zip tied to the back portion of the stock intake. No front portion of the air box.
  6. #6 Re: 04+ Intake shots
    Arizona
    My old setup
  7. #7 Re: 04+ Intake shots
    Pennsylvania, USA
    Eliminated all the stupid bends that add turbulence. I punched out a hole and fitted a grommet on the coupler attached to the throttle body to fit the breather hose. Used a low profile Spectre filter so it actually sits INSIDE my fender completely with no cutting required. Then used a roof baffle with some weather stripping on the edges to legitimately seal the come filter from the engine bay.
  8. #8 Re: 04+ Intake shots
    Oct 2011
    MI
    Nice. I'm planning on sealing it from the engine as well.
  9. #9 Re: 04+ Intake shots
    Oct 2011
    MI
    I'm headed up to Menards now for the parts. Can someone confirm throttle body diameter? I'm pretty sure it's 3" and the maf is 3.5" correct?
    So 3" to 3.5" coupler -> maf-> 3.5" to 3.5" coupler -> 3.5" pvc (maybe a foot and cut to length) - roof flange - air filter.
    Am I missing anything?
  10. #10 Re: 04+ Intake shots
    Feb 2013
    Detroit, MI
    MAF might be 3.25. I honestly used 3 inch couplers only n it fit everything. Then I had to get the flared PVC because my cones 4 inch.
  11. #11 Re: 04+ Intake shots
    Arizona
    maf is 3.25
  12. #12 Re: 04+ Intake shots
    Oct 2011
    MI
    So then 3" fit just fine? Or will 3.5" be too big
  13. #13 Re: 04+ Intake shots
    3.5" will still snug down on a 3" or a 3.25"...half an inch isn't that big of a deal (especially according to "she")
  14. #14 Re: 04+ Intake shots
    Feb 2013
    Detroit, MI
    Id go with 3..the tighter the better :thumbup:
  15. #15 Re: 04+ Intake shots
    Oct 2011
    Puyallup WA
    08 G8 GT - exhaust Tune
  16. #16 Re: 04+ Intake shots
    SWPA
  17. #17 Re: 04+ Intake shots
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  18. #18 Re: 04+ Intake shots
    Oct 2011
    MI
    See the only problem I'm having with a few of these shots are.. Your pulling hot air into the intake from the engine bay, I'm trying to make a Fwi so I can get those IAT temps down.
  19. #19 Re: 04+ Intake shots
    Jan 2013
    leavenworth ks
    i dont get hot air last summer when i drove id drive 19 miles (about 25 min) and I could drive at 80mph the whole way and when i get home pop the hood and my air intake would be ice cold tube and everything so i dont get hot air now if your in stop and go traffic your tube is going to get hot regardless and and your going to get hot air even if your filter is sitting in the fender or lowers. Putting the filter in the fender is only going to make the air have to travel further and take more chance of heating up.
  20. #20 Re: 04+ Intake shots
    Jan 2013
    leavenworth ks
    btw my heat sheild really helps to. To keep the filter from getting hot as fast in stop and go traffic.
  1. Pregen shots!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 03-09-2012, 12:07 PM
  2. Took some new shots of the car.....
    By cleangtp in forum Members Rides
    Last Post: 07-12-2011, 12:34 PM
  3. Engine Bay Shots!
    By Biohazed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 01:29 AM
  4. few shots of the GT
    By RDL04gpgt in forum General Tech Discussion
    Last Post: 05-02-2009, 03:30 PM
  5. I tried some night shots
    By David99GTP in forum Visual/Body Modifications
    Last Post: 03-28-2008, 06:25 AM
