Thread: 04+ Intake shots
Results 21 to 40 of 49
  1. #21 Re: 04+ Intake shots
    It really doesn't.
    Go get a scangauge and watch your IAT's.
    They're still sky high.
  2. #22 Re: 04+ Intake shots
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    thats why you need one of these a gpf sticker you get 5 more whp with it
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  3. #23 Re: 04+ Intake shots
    Stahp.
  4. #24 Re: 04+ Intake shots
    Quote Originally Posted by rperry435 View Post
    See the only problem I'm having with a few of these shots are.. Your pulling hot air into the intake from the engine bay, I'm trying to make a Fwi so I can get those IAT temps down.
    Sent using my Galaxy SIII on Tapatalk 2
    During regular driving and WOT runs, temps will be still around +10-20 from ambient, the only time the IAT's will rise is when sitting still or stop and go traffic.
    You have HP Tuners, go out and just log a normal route to work or somewhere and see for your self.
  5. #25 Re: 04+ Intake shots
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I did notice it in hptuners. And seems alot higher then it should. I already have a k&n off the maf.
    the temps for example would be 20° outside and 70+ IAT. Give or take a few..
    I usually don't wot ever.. And I haven't gotten my wideband yet so I haven't gotten into that phase of tuning.
    My driving is "suburban" lol one mile to work and back once for lunch once home.. Maybe 5miles total a day. A 30 mile trip once a week to the old man's house.
    When in moderate acceleration or for extended highway runs up too 100+ the temps never really drop much on the IAT.. I just figured if I could get as close to ambient/cooler temps that's only going to result in better performance. Probably not even measurable I know but it's the thought that counts? lol
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  6. #26 Re: 04+ Intake shots
    Arizona
    With the 04+MAFS they are very slow to respond to temps unlike the 97-03 guys once it gets hot it dosent like to move around much. since both the ls4 and v6 share the same maf i know what a piece of crap it is. If you look up my writeup on the ls7 maf install i have pics and diameters of the inside of it. and i would definatley recommend upgrading to either a breakout standalone IAT sensor or a northstar MAF etc... they are cheap, respond faster and easily keep up with your future mods.
  7. #27 Re: 04+ Intake shots
    So...you think a FWI will pull in colder air and help you with your 1 mile runs to and from work? This has been beaten like a whore on Saturday.
    Lets really be honest here...Intakes do nothing. you will be lucky to see a 2whp gain if that on these cars. And an intake outside the bay pulling in "fresh air" won't increase that number.
    Besides we have enough panel gaps that will let the cold air hit the intake in the engine bay anyways
  8. #28 Re: 04+ Intake shots
    Arizona
    Quote Originally Posted by Drunkie View Post
    So then why do u have a cone hanging off your maf like everyone else in this thread?
    I'm not saying these add 15whp but for the supercharged and v8 guys there are some decent gains to be had. And as far as temps it does matter if your tune has a. More aggressive spark iat table done
  9. #29 Re: 04+ Intake shots
    Becuz more whine from the SC!
    04 Comp G.
  10. #30 Re: 04+ Intake shots
    Yoga city
    on my gxp i have it near the fender well opening, but i took some the flexable intake piping and put something similar to drunkies couler on his intake behind one of the vents in the front buper. kinda just pushing the air. I know when me n cocoor where running it with HPT my temps were lower than a k and n setup by about 10 degrees
  11. #31 Re: 04+ Intake shots
    Oct 2011
    MI
    I'm trying to get cooler intake temps period. Its too high according to hptuners. Whether it give me hp or does absolutely nothing I have ocd when it comes to stupid **** like this..if it results in a better tune good if not so be it..
    personally I like the look of a fwi anyways.. I also don't like the look of a hai off the maf..im not saying I'm not in that exact boat at the moment (mine is a k&n stock filter without the pcm side of the box temporarly zip tied in place) and my previous 04 gtp was a cone k&n off the maf..
    Unless its fwi it just looks ghetto/ricey to me. No offense to anyone, anything is better than stock I'm sure just not a huge fan.
    Sent from my SPH-L710 using Tapatalk 2
  12. #32 Re: 04+ Intake shots
    Arizona
    **** that racekar mode everywhere lol
  13. #33 Re: 04+ Intake shots
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    yup....I cheated....
  14. #34 Re: 04+ Intake shots
    You know you can change that table so the PCM doesnt care what the temps reach. Instead of it flashing the red warning light at say 90, move it up to 120+.
  15. #35 Re: 04+ Intake shots
    Arizona
    I dont know about that one man, if youre IAT's are up to 120+ your MAT (manifold air temp) would be almost double that which is no bueno. think max id scale up to is 95*
  16. #36 Re: 04+ Intake shots
    I guess you don't understand what I am saying.
    Maybe the factory settings have the gauge flash red at 90-100, but if you don't give a **** like me, I set the red flash to turn on higher at over 120 because I'd rather not see it yelling at me that my IAT temps are getting really high while I'm not moving.
    I have never ever seen my IAT's above 100ish while moving and once I get into a run temps always jump down to around 10 above ambient.
  17. #37 Re: 04+ Intake shots
    Arizona
    Gotcha thought you were takling about the IAT vs. spark retard table but youre refering to the scanner warning settings. my mistake.
  18. #38 Re: 04+ Intake shots
    Oct 2011
    MI
    Finished mine. Total cost about $60. I'll pul it apart and paint the pvc black. No cutting was required
    Sent from my Galaxy SIII on Tapatalk 2
  19. #39 Re: 04+ Intake shots
    Now that's a nice intake
    04 Comp G.
  20. #40 Re: 04+ Intake shots
    Oct 2011
    MI
    Thanks. Wasn't too bad. I'm going to watch temps, see if I notice a difference
  1. Pregen shots!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 03-09-2012, 12:07 PM
  2. Took some new shots of the car.....
    By cleangtp in forum Members Rides
    Last Post: 07-12-2011, 12:34 PM
  3. Engine Bay Shots!
    By Biohazed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 01:29 AM
  4. few shots of the GT
    By RDL04gpgt in forum General Tech Discussion
    Last Post: 05-02-2009, 03:30 PM
  5. I tried some night shots
    By David99GTP in forum Visual/Body Modifications
    Last Post: 03-28-2008, 06:25 AM
