Thread: single to dual exhaust question
Results 1 to 14 of 14
  1. #1 single to dual exhaust question
    Jul 2011
    Illinois
    Will switching from single to dual exhaust on an 08 GP cause any problems with the engine? Maybe some back pressure issues? Thanks for any help.
  2. #2 Re: single to dual exhaust question
    Nope.
    Go right ahead and do it.
  3. #3 Re: single to dual exhaust question
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Back pressure is a ricer myth. If 10,000 hp top fuel dragsters can run straight headers without a problem, then a dual exhaust wont hurt you
    GPONA #1 Cyber Bully
  4. #4 Re: single to dual exhaust question
    Jul 2011
    Illinois
    Thanks guys. I am just now getting into modding and all this advice helps so much. Even though they are pretty simple questions
  5. #5 Re: single to dual exhaust question
    Quote Originally Posted by blackspike2710 View Post
    you need enough backpressure to allow scavenging to occur. what you just stated is incorrect, also.
  6. #6 Re: single to dual exhaust question
    Jul 2011
    Illinois
    I'm still alright switching to dual exhaust without anything else though right?
  7. #7 Re: single to dual exhaust question
    Pennsylvania
    10,000 hp top fuel dragsters are also pushing a lot more exhaust than a 3800...
    You need enough pressure in the pipes to keep velocity up, because as the gasses are leaving at a high velocity they're creating a vacuum behind them that helps pull the gasses farther upstream out better, which helps pull the gasses farther behind, etc
    If the pipes are too big the gasses are going to slow down in some areas, while being faster in other areas, making turbulence and choppy flow which overall hurts the dynamics of the system.
    And no, having a dual muffler cat back isnt going to hurt anything, some of them come factory that way, all you need is the pipe that splits after the cat.. I think it bolts into the cat end of the dp and then goes into the res and then splits right after the res.
    Sport Edition Kv5 18x8
  8. #8 Re: single to dual exhaust question
    Portland Oregon
    Correct. You'll just need to swap the rear valence to the dual cut out style
  9. #9 Re: single to dual exhaust question
    Jul 2011
    Illinois
    Ya I've been talking with Morad out of Ohio and they have an exhaust from a comp g that they can cut for me right before the y-pipe and ship it to Illinois where I am. They would have to cut it a second time after cutting it by the y-pipe to ship it. I would just need to weld that back together and then cut my existing pipe where the dual exhaust is cut by the y-pipe. Then weld the dual exhaust onto my existing pipe where my single was cut off. Then swap out the rear valence panels and get a couple more rubber hangers for the mufflers and I'll be set.
  10. #10 Re: single to dual exhaust question
    Jul 2011
    Illinois
    Just went and looked under the car. I will also need the prongs for the rubber muffler hangers that are bolted to the bumper. Does anyone have a parts number of that part?
  11. #11 Re: single to dual exhaust question
    Jul 2011
    Illinois
    I have found the part on shopgmparts.com but now I have another question about it. Would the driver's side exhaust hanger be the left side of the car or the right? I am thinking it is the left side but I am not positive and would hate to order the wrong part.
  12. #12 Re: single to dual exhaust question
    When you take it to the exhaust shop, have them hang it.
    They'll have hangers there.
    If they don't, well...then you need a new exhaust shop LOL.
    I'd also recommend some Dynomax Super Turbo/Borla/Corsa/SLP mufflers instead of the stock ones + some aftermarket tips.
    The factory mufflers sound poopy.
  13. #13 Re: single to dual exhaust question
    Jul 2011
    Illinois
    I was thinking about new mufflers also. May be a little farther on down the road. It sucks being a student and getting into modding. definately some new tips though. Does the dual exhaust have a rubber hanger next to the y-pipe? While looking at my single exhaust I did not see any hangers around where the y-pipe would be. This seems odd so is there a hanger that needs to be there to hang dual exhaust or do I just need to get my eyes checked.
  14. #14 Re: single to dual exhaust question
    Jul 2011
    Illinois
    Just got my dual exhaust delivered today. Now I just have to wait until thansgiving until I go back home from school to do anything with it
  1. Dual or Single exhaust...
    By HighOctaneRacing in forum General W body
    Last Post: 03-13-2011, 11:56 AM
  2. single or dual tips?
    By biggt in forum Visual/Body Modifications
    Last Post: 03-09-2011, 07:44 PM
  3. Impala Exhaust Question-single to dual?
    By Liquifire in forum General Tech Discussion
    Last Post: 10-14-2009, 01:16 PM
  4. single to dual exhaust?
    By Jcal1120 in forum General Tech Discussion
    Last Post: 08-15-2009, 12:51 AM
